carbon fiber radio box lid
  • urbs00007
    • Jun 2011
    • 857
    hi guys. running a wood rigger this year with 1/16 " carbon fiber radio box lid. was going to velcro receiver to underside of lid and run antenna thru plastic tube mounted in block of wood that will be j b welded to lid. any problem ? thanks
  • grsboats
    • 1011
    No problem.
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
    • RaceMechaniX
      • 3024
      I would recommend you try to get the antenna outside of the radio box and preferably pointed vertically. If the antenna end is parallel to the lid and inside the box you will not have great range. It would better if you taped the antenna to the inside of the wood tub pointed vertically if you did not want to run the antenna externally.
      You can always try it as you suggested with proper failsafes and see how far your range is.
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • Jamey
        • Apr 2015
        • 199
        Interesting! Pretty new to this stuff. I was about ready to glue an antenna tube flat underneath my deck on my new build. So you are basically saying the antenna (the working end) needs to be vertical? If I was to mount the antenna inside the hull how much does cf cloth up the sides and transom affect it? Does the antenna end need to be higher than the cf? My hatch and deck are just fg.
        • grsboats
          • 1011
          Jamey in a full c,f hull it is well known that this kind of material blocks some signals like GPS and can interfere with the radio range.Of course antenna's radio going outside is the safe option but I have some f.g riggers with c.f lids running with no issues with the antenna underneath them.What Tylers said is good to avoid troubles even in a wood boat.Gill
          www.grsboats.com.br
          • RaceMechaniX
            • 3024
            The antennae work best when the working end is vertical. CF will degrade the signal where as FG will not degrade as much. In boats were the antenna does not extend outside I try to tape them vertically inside the box preferably away from servo's or batteries. If you are driving your boat long distances away from the point where you are standing it is advisable to get the antenna out of the box, the higher the better.
            Tyler Garrard
            • Jamey
              • Apr 2015
              • 199
              Yeah function before form as much as I hate having an external antenna it is the best option. Thanks!
              • urbs00007
                • Jun 2011
                • 857
                yes tyler, i was going to run it thru the antenna tube out the boat. attaching the reciever to the underside of the lid gives me more antenna sticking out of the radio box.
