Just got Dunlap 27 Tunnel Hull Electric ARTR
  • runningman
    • Mar 2016
    • 103
    Dunlap 27 Tunnel Hull Electric ARTR with the following (pictures attached):
    1. Scorpion 1900 motor
    2. Outboard unit (I think he said it's K&B)
    3. Octura 440 propeller (3 blade)
    4. Aquacraft ESC
    5. 2 5000mAh Turnigy batteries
    6. Setup board
    Previous owner said that the boat can go 50 m/h.
    What would be a good propeller to slow it down till I get used to it? Previous owner suggested 38mm 2-bladed.
  • Beaux
    • Dec 2015
    • 550
    nice looking boat. It is a k&b leg. thats a good one it should move pretty good.
    • Beaux
      • Dec 2015
      • 550
      Even with a 38 mm it's gonna be fast you will have to control the trigger finger.
      • runningman
        • Mar 2016
        • 103
        Thanks guys. Looks like I'll need to set throttle output to 50% on my radio :)
        • runningman
          • Mar 2016
          • 103
          Beaux, what exact k&b leg is it? What flex drive is there? In case I need one to replace.
          • Beaux
            • Dec 2015
            • 550
            it is a 3.5 w/118 - 120mm cable 3\16th prop shaft.ose has relpacement gables that are quite a bit stronger than the mecoa cables and a nice selection of props also.
            • Beaux
              • Dec 2015
              • 550
              I have a k&b leg on mine w/a 3650 mm 2930kv and have not been able to open it up and keep in the water, still adjusting things. 50+ is not out of the question.
              • runningman
                • Mar 2016
                • 103
                Is that's the one? Or this one?
                • Beaux
                  • Dec 2015
                  • 550
                  i can't tell what your asking
                  • Beaux
                    • Dec 2015
                    • 550
                    you can pull your cable and measure should be 118mm but a120mm will work also it is a stilleto type cable ose cable is 120mm much better cable. mecoa cable is 118mm.
                    • runningman
                      • Mar 2016
                      • 103
                      I found some cables and wanted to know which one is good.
                      Hyper Performance 3.5 Flex Shaft
                      Upgrade Flex Shaft for ProBoat PRB4020 Outboard
                      • Beaux
                        • Dec 2015
                        • 550
                        Yes that is the exact shaft from ose ,plus he is anywhere from 1 to 2 bucks cheaper.
                        • runningman
                          • Mar 2016
                          • 103
                          Just to make sure: you are talking about Upgrade Flex Shaft for ProBoat PRB4020 Outboard Correct? :) http://www.offshoreelectrics.com/pro...hpi-dc1563s2AD
                          • Beaux
                            • Dec 2015
                            • 550
                            Yes sir, mfg by hyperformance. you got it that is a very good cable, check out his cnc props i picked up a 38mm and a 40 mm . Very nice quality.
                            • runningman
                              • Mar 2016
                              • 103
                              2-blade? 3-blade?
