What do they actually do ??
  • killerbob
    • Jan 2016
    • 25
    Turn fins.... Every boat seems to have them these days, bot what do they actually do ?
  • monojeff
    • Nov 2010
    • 2728
    Create a pivot point.
    Not all boats have them hydros and monos or v hulls are what benefit from them.
    It lets the boat pivot on the turn fin to help it make full circle turn.
    Without them many boats do not turn very well and some not at all really.
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    • killerbob
      • Jan 2016
      • 25
      So if i have a boat that turns so well that it actually is too much - then it might benefit from having the fins removed ???
        • 7512
        Possibly, but the turn fins can be adjusted for angle and some can be adjusted for depth as well...everything has an impact on handling. What boat are we talking about specifically?
        • RandyatBBY
          • 3943
          Making them smaller helps on over active turn fins too!
          Randy
          BBY Racing
          • killerbob
            • Jan 2016
            • 25
            It is the Watersnake from mn products. 55in v hull. Would love to skip them
            • martin
              • 2881
              Turn fins are not limited to just in turns, they can also help with chine walk. When the boat starts rocking from side to side in chine walk the tips of the turn fins touching the water either side as the boat rocks can stabilise the boat. As in teeter totting.
                So try it without and then you'll know what you need or not. Some hulls that have cupping at the back help a boat turn. Cupping in v hulls is bad for most people, some say they use it to avoid using turn fins.
                • RandyatBBY
                  • 3943
                  Like on a Suduser
                  Randy
                  BBY Racing
                  • iridebikes247
                    • 1669
                    I've seen the watersnake run w/o turn fins and it handled great, I drove it too. I'm not a hardcore oval guy but it was really impressive in the turns even with just trim tabs. I've seen quite a few watersnake run w/o fins.
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2751
                      Ive been asking this same question about politicians for years....
                      • killerbob
                        • Jan 2016
                        • 25
                        I'll give it a try without ...
                        Another Question: The most boats I have seen have the rudder mounted on the right side of the drive - a few has the rudder mounted left... Does it do any difference right vs. left ???
