Castle 5.5 mm bullet connectors
  • egneg
    • 4759
    I stopped by the LHS Saturday and picked up a couple of packages of these connectors and just spent the afternoon soldering them up to charge adapters, ESC, and a series harness. I went to hook things up and they did not fit my other 5.5mm connectors. I then got out the calipers to check them only to find out that they where actually 6.5mm. THE PACKAGES SAY 5.5 BUT CONTAIN 6.5 CONNECTORS. I don't know how wide spread this is or how many were distributed before they realized what happened (if they know). I just thought I would warn everyone before they end up in the same boat as I.
    IMPBA 20481S D-12
  • Ub Hauled
    • 3051
    thanks for the heads up...
    hopefully it's an isolated accident.
    • Steven Vaccaro
      Administrator
      • 8934
      Also you will always be better served to stick with the same exact manufacturer for these connectors and others. If you switch around from one manufacturer to another, A 5.5mm connector may not always be exactly 5.5mm. Some may fit loose or tight.
      Steven Vaccaro
      • egneg
        • 4759
        Thanks for that Steve as I have only used the one brand.
        IMPBA 20481S D-12
        • tylerm
          • 310
          What are yours if you dont mind me asking steve? Neu or sumin?
          Tyler.
          • Steven Vaccaro
            Administrator
            • 8934
            Tyler.
            Neither
            Steven Vaccaro
