This is about that 32" Delta Force copy that I bought off ebay. The motor is known to be too "hot" for that boat and a bit too small- BUT I have propped it down to a smaller prop and the boat will give me at least 7-8 minutes run time (probably more, but I never get a full run out of it
Now my problem- if I try to run it for the full charge without a break, after several minutes, it melts one of the motor wires off the ESC at the solder joint (same wire every time too..). If I bring it in and let it cool every 2-3 minutes, it is fine.
Sure, I'd say it is the motor drawing too many amps- BUT the motor is only rated at 50A max and the motor and battery temps stay in the 90's at the hottest indicating that it isn't pulling much amperage. Also, using the formula for approximate amp draw (Mah x.06/runtime) has me in the 40's for amp draw- which makes sense with my temps but should not be melting wires off like this.
Is it maybe just a crap ESC, or should I still look towards the motor? Is it possible something isn't setup right in the ESC programming causing it to get too hot? I'm waiting on the instructions from the seller on how to program it.
I'm tempted to try one of my hacker 70's in it, but I'm afraid to cook it if it is the motor causing the problems!!! Anyone know how good the ESC actually is that comes with it? How about maybe adding a cooling fan in front of the ESC to get air moving around it?
).Now my problem- if I try to run it for the full charge without a break, after several minutes, it melts one of the motor wires off the ESC at the solder joint (same wire every time too..). If I bring it in and let it cool every 2-3 minutes, it is fine.
