Boat skipping, not porposing
  • dontrinko
    • Jun 2014
    • 85
    I have an old Traxxas Villain EX. At full throttle it skips across the water. If i back off just a little it is fine. It is not porpoising and the bow is not high, the boat skips level above the water with only the prop and a tiny part of the hull in the water and it is not hard to control.
    If it was porpoising i would lower the props. What will fix this? ( other that a different boat) Thanks; Don
  • StevenBryant
    • Nov 2012
    • 366
    Do you have a video as I'm not sure what you mean....
    • dontrinko
      • Jun 2014
      • 85
      no video. boat rides level but skips across water like if you skip a flat stone. Props stay in the water and boat does not cavitate or slow down. Don
      • StevenBryant
        • Nov 2012
        • 366
        Can you get a video of it running? As it would really help
          I've had a couple of smaller boats that once I got to high speeds they would skip. Problem is they were just too light.
          • SweetAccord
            Speed Passion
            • 1322
            Is the water like glass? Is it windy? Have you adjusted your COG? Did you adjust the strut? Are there trim tabs to adjust? All these play on the ride attitude.
            • dontrinko
              • Jun 2014
              • 85
              no wind, no trim tabs, water smooth, boat villain ex. props are almost all the way down. I did do a crude check on cog and it apears to be near the middle of the boat with the battery's in. There is not much room to adjust cog without adding weight. Don
              • SweetAccord
                Speed Passion
                • 1322
                Adjust prop up a little. You may be causing lift going down.
                • dontrinko
                  • Jun 2014
                  • 85
                  Thanks for all the ideas. I made a few adjustments. It may be a while before my next run, Ohio is not the best weather for boating. Don
                  • SweetAccord
                    Speed Passion
                    • 1322
                    Ohio has the most man made lakes!
                    • dontrinko
                      • Jun 2014
                      • 85
                      also cold and windy this time of year!! Don
                      • SweetAccord
                        Speed Passion
                        • 1322
                        Yes it is. Stay warm!
