prop nuts or bullets
  • ozzie-crawl
    • Sep 2008
    • 2943
    does anyone use the bullet ends that go on the end of the prop or do you just use a nut. just wondering as i have a couple of bullet ends but dont know if there is any advantage useing them or if they put the prop out of balance.
  • andym
    More Go Than Show Prop Co
    • 2454
    I use them with a small lock nut, do not know if they make her any faster but they sure look good, a little bling never hurt anyone. I believe the theory is that it helps with the cone shape of the roost
    • Diegoboy
      • Mar 2007
      • 7443
      I have lost 2 new props thanks to the bullet nuts. I don't use them anymore.
      • tth
        • Apr 2008
        • 1600
        In my experience i have never been able to get the bullets tight enough so they always come off usually resulting in a lost prop..........just my dos centavos!!!
        • ozzie-crawl
          • Sep 2008
          • 2943
          thanks for the quick replies. yea like the bling bling factor. was going to put a small split washer on between the prop and bullet to see if that holds on. but i just finished a couple of new props and dont want to loose them
          • andym
            • 2454
            I use a lock nut and some nut retainer and have never had a problem.
            • ReddyWatts
              • 1756
              A bullet nut could help if you are using totally submerged props. They do not help when using surface piercing props. I use a small lock nut.
              ReddyWatts fleet photo
              • Raydee
                • 1619
                Aeromarine sells their bullets with a nut that goes on first. You tighten the nut on the prop and then tighten the bullet on the nut. They are rock solid.
                Team Liquid Dash
