Delta force 33 hardware question.
  • Nikolas Andriop
    • Jun 2015
    • 73
    Hello.
    I have a DF33 bare hull and i want to ask what type of shaft holder sould i use???
    Stinger or strut???
    I was thinking Speedmaster stinger which is longer than the below and measure approx. 82.5mm(3.25") in length http://www.offshoreelectrics.com/pro...os-stinger-str
    or that one fron Kintec 3/16 Adjustable Stinger. Has 2 Teflon bushing installed Distance from transom to end is 3 1/16inch (78mm)
    or strut
    http://www.offshoreelectrics.com/pro...=ros-spdss-002
    http://www.offshoreelectrics.com/pro...d=ros-spds-005 and from that style flat or round bottom????
    Also please tell me where sould i drill (How high??) for the hole at the transom
    Thanks!!!!!!
  • Nikolas Andriop
    • Jun 2015
    • 73
    Anyone?????
    • madmikepags
      • Aug 2012
      • 1371
      Round bottom strut and use a wet well.
      We call ourselves the "Q"
      • StevenBryant
        • Nov 2012
        • 366
        On the DF33 I run the strut 7mm offset to the right, and 7mm high. I run a round bottom custom stainless strut extended out to 75mm. Using a Teflon liner exposed from the transom to the strut so you can adjust the night easily. I run the strut with -1 degree and the COG at 33%. No trim tabs required on my boat, I run the esc, receiver on the left, cells down the centre, and motor towards the transom. Hope this helps
        • Nikolas Andriop
          • Jun 2015
          • 73
          7mm to the right for the prop walk..???Correct???
          What is the advantage of the strut over the stinger at the Vee??
          Im thinking the esc - motor and servo to the middle and the batteries to the sides left and right(i will running 6S2P)
          i will not put trim tabs either only turn fins 56x22mm
          The motor is TPPOWER 4050 2050KV 3Y and Seaking 180A plus cap bank
          Im from Greece and sorry for my english
          Thanks for help.
          I read many threads at the forum but i was try to open a new one for my boat
          Thanks again
