Does anyone use Corrosion X on anything else but electronics for waterproofing? I would think it would be great for bearings in the strut, drive shaft, drive nut, wire or flex drive, drive dog, and prop even? It claims to be a lube also and bonds to metal on a molecular level. No grease does that, and bar oil can't do that which seems popular by OSE members. So if that is true then why is nobody using it as a lube? It's supposed to be more slick than teflon in the specs. "As a lubricant, CorrosionX offers a lower coefficient of friction than even PTFE-fortified products (the Teflon, semiteflon, and other polymer-bead compounds)."
I have FrogLube for guns and that is very slick but have not tried it as a lube in boats, was wondering if anyone has tried that and how it worked?
Thank you.
Thank you.
