SV ESC size?
  • Rex R
    • 992
    SV ESC size?
    anyone happen know(and is willing to share) what size(physical) an sv esc is? I'd measure mine but don't wish to take apart the sv to do so. thinking of making a couple of cooling plates. thanks.
    rex
  • ChaKane
    • 131
    60mm x 35mm x 8mm.
    • Rex R
      • 992
      thanks much!
      rex
      • ChaKane
        • 131
        No probs rex. The caps extend a bit beyound the 60mm but I didn't add those to the length because you wouldn't be trying to cool those.
        • Rex R
          • 992
          well the caps are not usually big heat producers...but when they go, you don't want them enclosed . if I remember...I'll try and take(and post) some pics of the finished product.
          rex
          • ChaKane
            • 131
            I'd be interested in how it goes...
            • jwt
              jwt
              • 59
              cooling plates
              rex
              rex
              i have made cooling plates for my sv esc, made one from brass shim and another from alum, the brass is 4mm thick, and the alum is 6mm thk, i use the standard cool heat sink one side and the cooling plate the other, and find a temp drop of 10 to 15deg f, some heat transfer paste in between them..
              jwt
              • Rex R
                • 992
                I've got the plates made(used 0.8128mm brass plate(0.032"))...just need the esc to install them onto . I figure the esc ought to arrive by wednesday.
                • Rex R
                  • 992
                  installed the esc in my classic shovelnose. after 9.5 laps w/ a 640 prop the esc temp was 75F :)
                  • NorthernBoater
                    • 811
                    How did you make the aluminum heat sink. I have thought of trying to make a better heat sink of the Hydra 120.
                    • Rex R
                      • 992
                      personally I would use brass or copper and 'simply'* solder the tubes on
                      *had to use a torch for my plates.
                      • bonewar
                        • 549
                        very nice work there Rex.
                        SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
                        • Rex R
                          • 992
                          thanks. I thought it turned out nice too . I did wonder if I would need a shoehorn to get the packs in and out though...(not quite, but close)
