trim tabs position
  • RunningBeer
    • Aug 2014
    • 90
    trim tabs position
    Hi everyone, I have been searching the threads here for a definitive answer regarding trim tab placement off the bottom corner of the hull ( not from the keel but up from the bottom). The best answer I can find is 1/32" (0.8mm@). I would be grateful if some of you build masters could chime in here with your views. Many thanks R.Beer.
    Up 1/32" is okay, I usually aim for 1/16". The important thing is up off the bottom of the hull to reduce drag when the tabs are set up or parallel to the bottom...
    • RunningBeer
      • Aug 2014
      • 90
      ...Thanks Fluid,I'll go for your recommendation.
      • RunningBeer
        • Aug 2014
        • 90
        Hey Fluid if you're still out there, I have an ancillary question. I'm making some custom tabs 30mm wide, how long do you think they should be? They're going on a 35" DF Pirate. Thanks R.B.
