4mm Motor shaft to 5mm adapter??
  • Darin Jordan
    • 8332
    I'm looking for some adapter sleeves to make a 4mm motor shaft adapt to a 5mm collet.
    I have 1/8" to 5mm, but can't seem to find 4mm to 5mm.
    Any info would be appreciated.
    Thanks,
    Darin E. Jordan - Renton, WA
    • 9438
    If you can find a scrap motor with 4mm shaft, the internal brass shims may be 5mm. You can also look on eBay at the sellers from China. So far closest I've seen: http://www.ebay.com/itm/Round-Brass-...item43dc4fde32
    • RaceMechaniX
      • 2825
      5mm shaft?
      This is one of the few 4mm collets I have seen: http://mbp-rc.de/Spannzange-4x32mm
      TG
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • Darin Jordan
        • 8332
        5mm shaft?
        TG
        Actually, something like this is what I'm referring to:
        This is for my motor test bench, to allow me to use the 5mm sized high-precision prop adapter on a 4mm motor shaft.
        Maybe I just need to get a 4mm reamer and open up one of these.
          • 9438
          I hear you. Couldn't you machine that out in a lathe? Just use numbered drills and lots of cutting fluid.
          Oops, missed your last sentence...
          • RaceMechaniX
            • 2825
            just get some seamless metric tubing. http://www.mcmaster.com/#standard-metal-tubing/=zc720l
            Tyler Garrard
