Hello all hope everyones Labor is going or has gone great. I have recently completed my ML Q Sport Hydro, I have a Swordfish 220 running 6S and a Futaba stick radio, that is were I need help I can not get the radio to work with the correct position of the stick. I have reversed the Throttle and all I get is at neutral stick in middle (due to spring return) is WOT and all the way up is off. I cannot seem to get it where it is normal. Any help with this would be greatly appreciated as boat is just sitting. Thank You Jerry
Need assistance on set up
Throttle stick should not have any centering spring. If you are using a different stick, say elev/ail, then reverse the elevator travel and re-calibrate. Trying to figure out what stick configuration you are trying to accomplish. Are you trying to put throttle and steering on the right transmitter stick?
