HK Princess Review
  • floatsonwater
    • Aug 2015
    • 17
    #31
    Perfect timing! I'm about to order some thing from OSE and was debating about a longer rudder so I think I will add to the list. Did it help at all with left turns?
    Here is what I'm going to order:
    Speedmaster Stinger I guess this part was just updated so I'm waiting to hear back on the dimensions to see if it will fit on the transom. The current model is a tight fit and may not work so hoping this upgraded one has a smaller footprint.
    http://www.offshoreelectrics.com/pro...os-stinger-str
    OSE Upgraded Flex Cable
    http://www.offshoreelectrics.com/pro...se-cable-mcrew
    Trim Tabs Need to double check measurements...and still wondering if this will provide any benefit.
    http://www.offshoreelectrics.com/pro...prod=ose-80925
    Extended Rudder
    http://www.offshoreelectrics.com/pro...prod=ose-80052
    • zooma
      Local club FE racer
      • May 2014
      • 653
      #32
      Yes, improvement in left turn at all throttle settings.
      I am going to stick with my modded stinger with the 3/16 bearing. Otherwise I have to buy a second flex cable.
      Please report on your progress, I'm interested in the trim tabs.
      Ron - The Villages, FL
      • zooma
        Local club FE racer
        • May 2014
        • 653
        #33
        If you are using the stock prop, cavitation may still affect the steering.
        • floatsonwater
          • Aug 2015
          • 17
          #34
          I ended up returning mine do to so many problems and they sent me a replacement which from first looks has some nice upgrades on the inside. The motor was moved way back and there is also a much nicer composite servo tray. No tray for the esc anymore. Don't remember what the old prop was, but I fell like this one is different. Could be wrong.
