1521 shaft size
  • azjc
    • Sep 2008
    • 57
    1521 shaft size
    I have seen the 1521 comes standard with a 8mm shaft, what size is everybody using? I am assumming the larger size makes for a stronger shaft...is it making a difference?
  • Raydee
    • 1603
    I highly doubt it will make a difference in strength but the physical size of the bearings might make them last longer. If it was me and I had a 1521 with a 5mm shaft I wouldn't worry but if I was buying a new motor I might opt for the 8mm shaft simply because of the "Bigger is Better" theory
    Team Liquid Dash
    • azjc
      • Sep 2008
      • 57
      if the can is the same size and the shaft is bigger wouldn't that make the bearings smaller?
