Help
  • Thomas Schlarb
    • Jun 2014
    • 509
    I've got the same motor.. on 1280kv you need to run 8s high discharge batteries.... 10 to 12 gage wire and you need a BIGGER ESC... like grsboats said SF240 or the SF300..
    • Thomas Schlarb
      • Jun 2014
      • 509
      Sorry 8 to 10 gage wire
      • Thomas Schlarb
        • Jun 2014
        • 509
        Big FE boats cost a lot and if you don't do it right it'll cost you a lot more... lol
          ok so far I have to run 6s batteries with what I have at 1280kv
          so can someone tell me what bat to buy part# would be very helpful
          wire size anyone have any paperwork for anything thanks jim
          Let me be frank with the OP. What kind of speeds are you expecting? Running 6S with relatively low Kv motors will really limit your top speeds. Depending on your goals, you are making a lot of compromises which will work against you. Why twins for a first boat? Why a huge unproven 50" rigger...arguably the most difficult type of boat for a beginner? Boats like this are tough for FE experts to make work. I have seen MANY beginning FE boaters make simple mistakes which cost hundreds of dollars - compounded with a big, expensive boat.
          There is no "paperwork" for boats like this, very few folks build them - BTW I wrote the book on FE boats (one anyway). The fact that you know so little about FE is a warning NOT to build this boat until you have some experience with smaller, simpler boats. From the FE beginners who I have watched, you have a 90% chance of failure with the big rigger. Do yourself a favor and shelve it for awhile and get an RTR first. Learn, make the mandatory beginner mistakes, then go big and fast with the right equipment.
          • grsboats
            • 1011
            Agreed with Fluid....very good advice/warning here!
            GO FAST AND TURN RIGHT !
            www.grsboats.com.br
            • Thomas Schlarb
              • Jun 2014
              • 509
              Same here.. great advice
              • jk20041958
                • Dec 2014
                • 10
                ok im already getting smarter with this electric stuff here is what I am starting with as some know my motor, 180 esc, the bullet connectors are 7or7.5 ? can you tell me, the batteries are 6s but what milliamps should I be able to run, #10 wire. and can anyone take a pic or two of this motor set up, again I am thankful for all the help its just not something I have built before, nitro and gas engines are what I know thanks jim
                • Thomas Schlarb
                  • Jun 2014
                  • 509
                  8mm connection on the motor to ESC. 6mm connection on the batteries. Again that motors kv is to low to run 6s...you need 8s and if you read the amp draw for the 1280kv configuration the 180 ESC is to small... and max MAH is 10000 in a race boat..
                  • jk20041958
                    • Dec 2014
                    • 10
                    so there is no way to run that esc? I was at a hobbyshop Friday and 8mm bullet connecters would not work just a tad to largeand 6.5 were way to small, too wire the back of the motor, soo will a larger esc change the MAH or is that a standered, also the wire size should be larger as opposed to smaller 8 - 12 with a larger esc
                    • Thomas Schlarb
                      • Jun 2014
                      • 509
                      MAH is just the compacity of the batteries.. more MAH the longer they will last... like we've been saying there is no standard when it comes to big FE boats.. only RTR.. I buy my own connectors and solder everything myself. I'd say no with that ESC. It'll run 6s and you need 8s or more. A larger ESC will provide you with the amp draw you'll need and you can run the voltage you need as well. Stick with 8 to 10 gage wire as well... just trying to help so you don't put it on the water and it last 10 sec and cost you hundreds of dollars.
                      • grsboats
                        • 1011
                        Specifications
                        X520 3Y System
                        Watts: 5280W
                        Max Voltage: 41V
                        Max Amps: 128A
                        Resistance: 0.0132
                        KV (RPM/volt): 730
                        Max RPM: 30000
                        Length: 102mm
                        Diameter (w/fins): 55.8mm
                        Weight: 925g
                        Shaft Diameter: 8mm
                        Length of extend shaft: 30mm
                        X520 3D System
                        Watts: 5280W
                        Max Voltage: 23V
                        Max Amps: 229A
                        Resistance: 0.0046
                        KV (RPM/volt): 1280
                        Max RPM: 30000
                        Length: 102mm
                        Weight: 925g
                        Shaft Diameter: 8mm
                        This is the data of your motor....take a look to those numbers ...definetively no way to use your esc and be on the safe side!
                        www.grsboats.com.br
                        • Thomas Schlarb
                          • Jun 2014
                          • 509
                          very one I know is running this motor is running it on 10s in the 3Y configuration.
