I've talked to several people about this and I only bring this up because I was shocked to find out they don't bother with this or haven't thought about it......
When you grease or lube your flex shaft, as your sliding it back in the tube, the tip of it is collecting grease. Then if you slide it into the collet like that, you have grease in your collet....at the point where it's supposed to grip. Now. I've had boats that I didn't have any problems ommiting this crucial step, but it's always a good idea to clean the shaft before it goes into the collet. You never ever ever want grease in there. Especially in a high powered setup.
The way I do it is I get a rag and shoot some brake parts cleaner in a small area. I then slide greased shaft in, as I see it start to make its way out the stuffing tube, I rotate it slowly and push in slowly while wiping with the rag. It takes time and patience but I've had a boat dead out in the water because I ommited this step being lazy and it stripped my collet and end of my flex. So for now on, it's a good idea to do this. I know most of you veterans know this already, but for the guys who don't....take this advice and Use it. Also, you can scuff the tip of you flex with 60 or 80 grit and it will grip better.
