This brushless conversion learning process has taught me a lot, but I'm also not satisfied with the performance of the Shockwave 26 currently.
Download on setup:
HobbyKing 3000kv 2-pole Brushless Motor 4mm connectors
Aquacraft 45amp ESC w/ 5.5 bullets to battery
Stock .150 Flex cable from ProBoat
Amps and watt power measured with GT Wattmeter (Max values only), all tests with fresh 3S Zippy Compact 5000mah 11.1V 40C off balance charger
OSE Plastic Prop 1.4 x 38mm = 22.77mph | 93.06A | 1032.9W | Motor Temp 162 | ESC 116 | Batt 86 | Run Time 99 sec | MAH added 1608 | Average amps 58.47
OEM ProBoat Prop 1.34 x 41mm = 24.72mph | 99.00A | 1092.9W | Motor Temp 164 | ESC 120 | Batt 93 | Run Time 65 sec | MAH added 1285 | Average amps 71.17
Graupner Carbon Prop 1.4 x 40mm = 24.23mph | 84.00A | 943.30W | Motor Temp 124 | ESC 102 | Batt 77 | Run Time 70 sec | MAH added 1110 | Average amps 57.09
Graupner Carbon Prop 1.4 x 42mm = 25.14mph | 92.99A | 1047.0W | Motor Temp 121 | ESC 102 | Batt 79 | Run Time 75 sec | MAH added 0847 | Average amps 40.66
Graupner Carbon Prop 1.4 x 45mm = 25.66mph | 103.5A | 1159.4W | Motor Temp 160 | ESC 126 | Batt 93 | Run Time 66 sec | MAH added 1227 | Average amps 66.93
Octura S/B Prop 1.6 x 37mm = 24.45mph | 94.86A | 1135.4W | Motor Temp 129 | ESC 105 | Batt 87 | Run Time 45 sec | MAH added 0713 | Average amps 57.04
So to me this data says the best prop is the 1.4 x 42mm as far as speed and average amp draw correct? The thing that I am struggling with is whether or not this motor and ESC combo are worth keeping? I bought them for a good price and don't feel bad, I just know there is more potential. I have a 1500KV ProBoat 6-pole 3650 and a 45amp ProBoat ESC (From a Blackjack 26 I believe) that I might put in the hull and replicate all this data above and see where that gets me.
Any constructive criticism appreciated, thanks, Ken
Download on setup:
