graupner systems cat ques
  • waynedawg
    • 167
    hi
    im new to boats and have a ques. i picked up this grp systems cat i would lik to change the running gear and motor what is in it is junk. its 33in long and 10 wide any suggestion for gear and motor would be great. i have not yet gone to poly batt yet so staying with nmh thanks in advance
  • waynedawg
    • 167
    pics
    hers the pics
      That boat runs great with a 700 motor and 12 cells, it is very light weight. Use the flex cable drive, you can keep the rudder where it is for simplicity. Rigged correctly with an x445 prop it will run in the 30s.
      Another thought is a SV27 motor/ESC on 12 cells. A little more $$ but higher speed and performance. Try an x442 to start.
      • dan63043@gmail.com
        • Aug 2012
        • 11
        I have a graupner systems from 1988 that I built then but never put it in the water until last weekend.
        It rean fast until the gears came off from not tightenening them properly.
        I'm working on correcting that and can't wait to get it into the water again.
        I built it with Graupner's 606 hydrospeed dual motor setup. I'm going to convert the servo/micro switch
        full racing takeoff to an esp. Any idea how to attach pictures for you to see, I'm new here,
        Dan
        • domwilson
          • 4411
          Hit "Reply"
          Then click the "Go Advanced" button.
          Scroll down a bit and click "Manage Attachments"
          Then click "Add Files"
          Then "Select Files"
          It's pretty easy from there.
          Government Moto:
            • Aug 2012
            • 11
            great,
            I'll take some pics and give it a try,
            Dan
              I can't wait to see them pics.I used to have one myself and it saw many forms of motivation.
                • Aug 2012
                • 11
                my SYSTEMS
                Originally posted by waynedawg View Post
                hi
                I think you can only send 5 at a time.
                I'm attaching 5 of 10 pics (I think)
                if it goes through I'll try sending the other 5,
                Dan
                  • Aug 2012
                  • 11
                  more SYSTEMS
                  Here are 5 more, 1 left,
                  Dan
                    • Aug 2012
                    • 11
                    last photo
                    Hope they all got uploaded, there were 11 in all.
                      • Aug 2012
                      • 11
                      did you see them?
                      Dan
                        I saw them.Cool,memories... In mine I hooked up the guys heads to the rudder servo so when the boat turned left they looked left.Same with right.
                        I also switched the noisy gears to a Hyperdrive belt system before it got a single Astroflight 25 and 18 cells.Wish we had GPS back then.
                        It sure ran good back then.The ride pads are fairly narrow and the tunnel deep. So what are you're plans for her?
                          • Aug 2012
                          • 11
                          Well, I have a lot of catching up to do.
                          I understand brushless motors and lipo batteries are being used today.
                          I purchased 2- 7.2v 6800mAh ni-mh chinese made batteries to replace the older super stock fdm 2000 battery packs,
                          my thought was to get longer run time with these but do you think I would need to water cool the Graupner 600s?
                          I also purchased a proboat waterproof esc to replace the flat out full speed servo operated micro switch that was set up for racing.
                          I plan to just have some relaxing fun lake running it with the grandchildren, my racing days are over.
                          I would appreciate any suggestions you can make for me,
                          thanks,
                          Dan
                            thanks,
                            Dan
                            I had to make the conversion as well Dan.I was out of the hobby for quite a few years(since that Systems 7)
                            Started back with a Slash and OMG the power in brushless/lipo.I used to run a Tamiya Super Shot for racing and was lucky if I got 4 mins run time.I can go walking and bashing my Slash and the battery goes an hour.And it is killer fast.
                            Same goes for the boats,you just have to watch as the Brushless motors can pull some juice so pick your batteries well. 40c and up if you can.SkyLipo is a good start. This forum is good reading and will save you parts if you take the time to search for what you want.I think I read for 3 months before I posted anything.
                              • Aug 2012
                              • 11
                              thanks for the info,
                              as soon as i need to replace a 600 motor i will make the change.
                              meantime, i'll take your advice and read.
                              Dan
