can someone please id my rudder/strut assembly?
  • kwiktsi
    • Sep 2008
    • 647
    I built this boat several years ago with hardware purchased by fine design. For some reason he sold me a separate strut and bracket assembly for it. I am upgrading the boat to .150 flex and the existing strut won't work so I am looking to just remove the lower brackets and add a strut to the rudder bracket as it should be. It looks like the strut has to be about .090 thick where it slides into the brackets and needs to accept a .150 cable. Any ideas what will work here? Thanks.
  • JimClark
    • 5913
    Strut bracket looks like it might be from FineDesign he used to have some of those purple ones
    Billy Graham
    • kwiktsi
      • Sep 2008
      • 647
      Sorry, should have been clearer- I want to remove those brackets and just run a strut off the rudder assembly as it's supposed to be. I still have the purple strut but it's too small for the .150 cable. I need to either know who makes the rudder or who makes a strut that will fit into it so I can get a strut for it.
      I can just get a new rudder and strut assembly if need be, but would rather just do the strut. Thanks!
      Joe
        Rudder is older Hydro Marine from Germany.
        • kwiktsi
          • Sep 2008
          • 647
          Thank you. Do you know of any struts that will fit in there?
          • z400
            • 1333
            Fill the holes and start over.
            That wat you will know what you have.
            Z
            KBB34" Mono - Fast
            ToySport Triton- Not as fast
            • kwiktsi
              • Sep 2008
              • 647
              I would if I could find one I liked for it. All I see on ose are this one which is too big (same as on my 37" daytona) http://www.offshoreelectrics.com/pro...prod=ose-80085
              And this one which won't take the .150 flex and looks a little on the small side for this boat (30" bk bandit) http://www.offshoreelectrics.com/pro...ct-oc6str-130a
              Any recommendations? Thanks.
                Measure the gap in the purple mount and I can help more.
                • kwiktsi
                  • Sep 2008
                  • 647
                  I'm ditching the purple one all together and moving the strut to the rudder bracket since it is made for a strut as well. That one has about and .090 width opening for a strut to slide in.
                  I wish I knew why, but it was probably sold to me like this because he used the h&m strut on something else so he sold me the separate purple one to use.
