New to lipos, Have a quick ?
  • Spot Me 2
    • 770
    I want to know if it would be safe to run 2 lipos with a different c rating in series.
    They are both 5000mah packs. 1 is a 2s1p 12 c and the other is a 3s1p 25c pack. I would like to try them in me Formula Fastech, but don't know if you can mix c rating like that. Thanks in advance!!!
    MMGMMarine
    RobertsonRacing
  • NorthernBoater
    • 869
    I would not recommend it. The 12C pack will be the weak link in the chain. You will not be able to draw more current than the 12C pack can handle.
    • ED66677
      • 1300
      not good at all!
      always (not only with Lipo's) use packs that are the same, no matter if they are in serie or in parallel, I personnally use same brand, same age, same specs pack when connected together!
      Emmanuel
      • andym
        More Go Than Show Prop Co
        • 2454
        I am with Emannual, do NOT do it. At best you will stuff the 12c pack at worst a explotion and fire. Same MHA same C rating same brand is preferable and packs that are of a similar age. We get complacent with our Lipo's because good cells work so well but do not forget that they can be very lethal ! A 12c pack has NO place in a brushless boat. AT ALL.
        • SweetAccord
          Speed Passion
          • 1322
          Confirming, the "no". As the advice everyone else is already stating the C rating is too low too. It's the C rating you should always match, as for the MhA that is not that important, but always better to be the same or very close.
            • 7512
            No.
