Hi.
After only 1-2 minute of runtime on my new genesis twin motors the left prop stop working.
When i went home i took out the driveshaft in the strut and when i put the flex shaft inn it just slips inside the driveshaft.
Here is some pics, think its because the flex shaft is to thin or not have enough edges where it flat?
Maby i need a new driveshaft also.
Thanks for reply :)
Thanks for reply :)
, I like to say that the square end from No1 and 2 of the cables looked OK, at least with the pictures that you are supplying. As for the square hole in the shaft, can't tell, the angle is not the same and you need a REAL camera to have Macro capability to show if there is any abnormality.
