Castle BEC
  • SweetAccord
    Speed Passion
    • 1322
    Castle BEC
    I'm curious on the CC BEC voltage setting what is the voltage that most of you that use this set it to? I see in the BEC software I can set it to 5.9, 6.0, 6.1, 6.2, 6.3. I'm asking as I know the voltage should be 6.0v ideally, but four AA are a higher voltage like 6.02. Is there any advantage to have it like 5.9 to draw less voltage, or is it better to have it higher to provide the servo more torque?
    I will be using one servo (stock SV) and the CC Hydra 120.
    Thanks!!
  • Raydee
    • 1619
    I set mine at 6.2 volts just to be safe incase the voltage coming out is a bit lower. I use Spektrum receivers and they don't like low voltage.
    Team Liquid Dash
    • SweetAccord
      Speed Passion
      • 1322
      Will do. Thank you!
