So darn mad right now, need soldering help!
  • Tamelesstgr
    • Jun 2014
    • 1512
    So if I am looking for something more long term for my bench needs 80-100 watt?
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
    • T.S.Davis
      • 6228
      Do a google search for Tip Tinner. Helps with tips. Sometimes you can save one that was sanded.
      I haven't used my 80 watt iron in years. Not since end to end soldering Nimh cells. The 40 watt works for most everything I do.
      Noisy person
      • T.S.Davis
        • 6228
        Originally posted by iridebikes247 View Post
        The weller with a big chisel tip is a really good investment.
        http://www.hobbyking.com/hobbyking/s...arehouse_.html
        ^^-This thing is a renamed Hakko station I believe a 936. I've had two for 3 years, extremely powerful and with a chisel tip this will take care of 95% of jobs. I too use a torch sometimes but be careful you don't overheat the joint. Use 60/40 solder also.
        That's a killer deal. Do they sell tips for it too?
        Noisy person
        • electric
          • 1744
          This is the one I use. You can get it a lot of places.
          By the way, I am using the same tip as when I bought it four or five years ago...
          • Tamelesstgr
            • Jun 2014
            • 1512
            Read through the product comments and seems tips are available
            • Tamelesstgr
              • Jun 2014
              • 1512
              Well, gave the 25 watt another try tonight. I was able to solder end to end cables and shrink wrap them. I put a new tip in the iron and let it heat up. Dipped both ends in the flux, tinned the tip and then used the $3 harbor freight helping hands to melt them both together. This was still with the pencil tip. Tomorrow I might try my charger lead cables, so I will be doing 12ga wire to 4mm banana plugs and some xt60's on the opposing ends. Will give the chisel tip a try.
              • egneg
                • 4664
                Originally posted by Tamelesstgr View Post
                I was using pliers to hold the connector, and that got pretty warm, so it's pulling heat I am guessing. The tip will melt solder, but I think I ruined the tip because I sanded it. Of course I am not home this weekend, so now looking for a butane pencil torch or new tips.
                That is the problem, sucked all the heat away.
                IMPBA 20481S D-12
                • gb tiggycat
                  • 70
                  Been using my old Weller 80W soldering gun for all kinds of work since the mid 70's. Amazed that it is still going. Copes with connectors with no problem
                  • Tamelesstgr
                    • Jun 2014
                    • 1512
                    Soldering is going much better, even with 25watts. Chisel tip is helping, clean tinned tip helpling with heat transfer. I've soldered battery connectirs, made my own charge leads and some combo connectors like EC3 to XT60. Haven't tried the 5.5 bullets yet. Is there a common way to do those? Like positive red is the female etc?
                      • 5660
                      Hi Ken
                      I already messed up another thread, let's see how much more damage I can do.......lol...
                      On the ESC side, male connector on positive and female on negative.
                      Opposite on the battery. Red wire is soldered to a female connector, hence "red hot female"
                      • iridebikes247
                        • 1528
                        T.S. Davis-- The soldering station I had the link to is a Hakko 936 copy. I have been buying tips on ebay and a few other places for awhile now. This is one of the chisel tips.
                        http://gokimco.com/hakko-t18-s3-chis...QWkaAvKt8P8HAQ
                        Anyway this station is an animal and is cheap enough to always have an extra laying around. Sometimes I'll use a torch to break joints but this really has done the job for the past 3 or 4 years.
                        • electric
                          • 1744
                          Hi Ken
                          Never heard it put that way, but will never forget anymore..LOL I do it the same way...
                          • Tamelesstgr
                            • Jun 2014
                            • 1512
                            Thanks for the Tip Tim.
                            • kevinpratt823
                              • Aug 2012
                              • 1360
                              Hi Ken
                              That's just crazy talk Tim. Your input is always valid and constructive.
                              Sent from my SM-G920V using Tapatalk
                              My private off road rc track
                                • 5660
                                You are too kind, sir.
