what next
  • hammertime
    • 517
    what next
    ok so i ran the quannum motor on 14 cells today.....great run by the way....it gave me a real long run time in my cat but the speed was not as much as the sv motor....... on 14 cells it was just as fast as the sv motor on 12 maybe slower..... should i a: make some 8 cell batts and run 16 cells.....B: by the sv motor and run 14......C: by the ammo motor and run 14.....D: by a fiego
    60% of the time... it works every time!
  • hammertime
    • 517
    ps i loved the way this motor sounded at speed....
    • hammertime
      • 517
      also i have a 70a esc
      • saleens7
        • 1130
        those quntam motors arent as good as a feigao or any of the other motors you suggested, they dont last as long and usuallu wear out way before a feigao will...
        its really supposed to be a plane motor...but you can try it for now if you want to...
        • Steven Vaccaro
          Administrator
          • 8934
          If you want to be faster than the stock supervee you will need a motor with similar physical size and higher kv value. You can run a 10L or 12L. Make sure with any motor change that you start with the smallest prop and work upwards.
          Steven Vaccaro
          • hammertime
            • 517
            ok.... well i have a catamaran it was almost if well into the 40s with the sv motor on 14 cells..... i wonder if i prop up and add cells if this would work...... the motor and speed control were not even hott
            • Steven Vaccaro
              Administrator
              • 8934
              I'm kinda lost. Which boat and motor are we talking about. I thought you were talking the sv hull and quannum motor?
              Steven Vaccaro
              • hammertime
                • 517
                no i have a bk bandit s catamaran i first took the sv motor and esc out of mt sv and put it in the cat..... than i put the other esc and quannum motor in the cat..... im goin to advance the timing on the motor a little and see what results i get..... it was fast but the sv motor was faster.... i also got a really long run time so i might prop up..... im running a x440 3 blade..... would a bigger 2 blade be better??
                • Steven Vaccaro
                  Administrator
                  • 8934
                  Thats because the quanum is a much lower kv. Play with the formula on the bottom of this page to get some ideas.
                  Steven Vaccaro
                  • hammertime
                    • 517
                    what formula
                    • Steven Vaccaro
                      Administrator
                      • 8934
                      Sorry I forgot the link!
                      http://www.offshoreelectrics.com/conversion.htm
                      Steven Vaccaro
                      • hammertime
                        • 517
                        wow im not sure how to do this...ill figure it out though thank you very much
                        • Steven Vaccaro
                          Administrator
                          • 8934
                          Take another look at the formulas. It was changed in the conversion. It should be easier to understand now. Just change "yellow" fields to the numbers that you know.
                          Steven Vaccaro
