what flex or wire drive setup to use?
  • kwiktsi
    • Sep 2008
    • 647
    I have a bk bandit s cat with a nemesis 8xl on 4s. The current flex shaft measures .128 (.130 flex?) With 3/16 stub. I never had flex issues with this boat before but stepped up to higher c batteries and a 642 prop today and the flex let loose. Before I order a replacement, I just want to know if this is an ideal drive for this setup or if I should swap it out now for something else? Thanks.
    Joe
  • Jeff Wohlt
    • 2740
    078 wire or certainly a 150 cable is needed for that setup.
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • kwiktsi
      • Sep 2008
      • 647
      That's what I thought. This boat was built about 8 years ago or so and was running 12 cell nimh, so that is probably why they had me use the .130 cable. Want to build me a drive for it :)? It will need a 3/16" stub or I'll need a different strut. Will wire make an "s" bend? The motor is laying flat in the hull, so it needs the s bend. No room under the hatch to angle the motor.
      • NativePaul
        Greased Weasel
        • 2770
        Even back in the NiCad days most people round these parts were using .150 flex for 12 cell boats. I'm not a fan of "S" bends, but if you really have to have one, go with a flex shaft not wire drive.
        • Jeff Wohlt
          • 2740
          Yes...the wire does not like an S bend. Sure I can get you one or you can get one right here from Steven as well.
          Sounds like a boat built by Chris Fine...is that possible?
          www.rcraceboat.com
          • Heath M
            • Mar 2008
            • 865
            If your going to step up to a thicker flex you'll have to redo the stuffing tube as well.
            Brisbane,QLD, Aussie
            • kwiktsi
              • Sep 2008
              • 647
              Very close, good guess! Built by me, parts bought from Chris per his recommendation.
              See above, this is what was recommended to me at the time. I have to admit, while it doesnt have a whole hell of a lot of runs on it compared to what you guys run, its the original flex from when I bought it, so it did last a while. I'm not a fan of the s bend either, but options are limited due to the hatch design not allowing the motor to be angled.
              Yup, already aware of that.
              Thanks for the info guys.
              • Jeff Wohlt
                • 2740
                So just put a 150 cable in it. It will be fine for 4s
                www.rcraceboat.com
                • kwiktsi
                  • Sep 2008
                  • 647
                  Ok, I'll go that route. Thanks Jeff.
