Additional Water Pickup Question
  • jakevisser10
    • May 2015
    • 100
    So I installed an additional water pickup on my revolt between the left turn fin and trim tab. I thought that putting it between the trim tab and strut would lead to more prop slippage. The way I look at it, it is either prop slippage or more drag...any insight?
    Can you post some pics of it?
    • jakevisser10
      • May 2015
      • 100
        Are you having any problems? What exactly is the purpose or point of your question?
        • jakevisser10
          • May 2015
          • 100
          If the spot I installed it is ok. I always see people install it between the trim tab and strut, which I feel would lead to more prop slippage. The place I put it will have more drag, but not increase slippage. At least that is my though process behind this.
          • lt130th
            • Apr 2014
            • 858
            Fundamentally, the worst shape of an object in a fluid flow is a circular cross-section/sphere, concerning drag. The turbulence from flow separation at the trailing edge is the problem. Thus, dragging a pipe behind the boat is probably the worst type of water pickup you can have.
            That turbulence could affect your prop's performance by introducing dirty flow to a fraction of the flow across the area of the propeller disk. Take what you will from that. I do not claim to be a specialist in fluid dynamics or the study of boundary layer phenomenon.
            • jakevisser10
              • May 2015
              • 100
              What would you recommend without having to drill through the hull?
              • boilo56
                • Aug 2014
                • 390
                I think most people place that kind of pick-up near the strut because that spot is always in the water, so the water flow is more constant. But there might be some other reasons.
                • jakevisser10
                  • May 2015
                  • 100
                  Yeah I completely get that, but I feel like it would lead to a lot of slippage
                  • boilo56
                    • Aug 2014
                    • 390
                    Mine is at this spot, and didn't noticed much change on the boat. But i'm not a racer, only a mad scientist!!!
                    • lt130th
                      • Apr 2014
                      • 858
                      Dual pickup rudder? Honestly I think the effects will be negligible. Your pickup will probably work fine where it's at as far as performance goes. These RC boats are not crafted with aerospace precision.
                      • boilo56
                        • Aug 2014
                        • 390
                        Mine is at this spot, and didn't noticed much change on the boat. But i'm not a racer, only a mad scientist!!! Only the beveled part of the pick-up should see the water. here is mine:IMG_20150530_233656.jpgIMG_20150530_233817.jpg
                        • jakevisser10
                          • May 2015
                          • 100
                          im only going to be sport running this boat, so the speed doesnt really matter that much, its more of a question of whether or not it will affect the handling.
                          • boilo56
                            • Aug 2014
                            • 390
                            No, It shouldn't affect the handling.
                            • lt130th
                              • Apr 2014
                              • 858
                              ...its more of a question of whether or not it will affect the handling.
                              Physics says you're creating a torque about a point/axis by the drag force acting over the length of the moment arm. But that's what you have rudder trim for, in this case.
