newbie needs some help first boat set up
  • ando
    • 7
    hey all,need some advice on what esc i should buy,i have this cat from http://www.r2hobbies.com/proddetail.php?prod=rcbt1107_N and have not had much fun on the water with the set up it came with ,so from doing some research on this forum it seems a 8xl sounds like the go i have a hand full of 14.8 lipos 15c and not sure where to go for a esc (may be the castle 120),i also have a x440 fitted, any advice for a first fun cat would be great,oh it ran well for a few mins before the plastic melted of the 80 amp esc the cat came with .
    cheers, ando.
  • ozzie-crawl
    • Sep 2008
    • 2943
    hi ando i have one of these boats but with diffrent motor mount and doesnt have the battery holder. i was running a 6xl 2800kv motor on 4s but it was a bit to hot of a setup so i have ordered a 7xl 2384kv motor from ose. try and tame it down a bit. but it will still be good for over 80klmh. have seen one setup with a 8xl 2084kv running a castle 120amp esc and a 42mm carbon prop that was doing 80 klmh. if you try this setup put your esc were the battery mount is and run a pack down each side to get the cog rite. good luck
    • ED66677
      • 1300
      you will need some 20C lipo minimum! the 8XL will fry your battery
      Emmanuel
      • ozzie-crawl
        • Sep 2008
        • 2943
        yea sorry missed the lipo bit also i was running 4s 2p 20c 2200mah but have changed to 3700mah. x440 prop
        • ando
          • 7
          thanx guys ill get some better lipos , 8xl ,and i think the castle 120, have pulled out the wood mounts and orderd a better mount for the 8xl will run 2 packs as ozzie sugested for cog.
          • ozzie-crawl
            • Sep 2008
            • 2943
            just a small warning to if this is your first fast electric. with a 8xl and a 42mm prop its going to be fairly fast
