Shocker First Maiden Run -- ESC Literally BLOWS through Hull
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    #76
    srislash: Yep. Sounds like a combination of things gone bad... and ka-boom :) The builder was just in a hurry I could tell. Was even missing a bolt on the rudder.
    Yeah dude sounds like you've got the driveline free so I say go ahead give it another go. Short runs checking temps between.
    Doesn't sound like your setup is wrong or anything.
    As far as everyone's comments, you have to take stuff with a grain of salt. Different setups combined with different running styles equal different opinions.
    Some guys run a couple of quick passes and that's it, some guys run flat out for 3-4 minutes. There's a huge difference in what your setup will handle based on that alone.
    • Spartanator
      • 1060
      #77
      As for my rather short RC record, I run flat out if able to.
        Make Total Destroy
        • Mar 2014
        • 1952
        #78
        Well, as an example, because it's been discussed in here... A 2200kv motor running 6s flat out for 3-4 minutes is gonna be a tough one for a single setup.
        I ran the castle 2200 on 5s for those runtimes, but that was pushing it imo.
        However.. I've never tried 6s on that motor so I really couldn't say for sure.
        Not something I would bother trying tho.
        • iridebikes247
          • 1669
          #79
          This boat should be able to take a beating, check and re check multiple times. This shocker will never EVER run like an oval boat, data logging alone will show you that. Large spikes followed by lulls, thats how it goes with SAW.
          I can't comment on the new seaking im not sure if they burn easily or not. I can say the new sf220/300 is pretty good for the money.
          I think buying a few batteries will be a good idea. You have 3s, so I'd get two 2s packs also, move up so long as escs/motors are identical in temp. Also check the soldering on the motors make sure the guy before you didn't do a bang up job.
          • keithbradley
            • 3671
            #80
            Um oops ... I kind of misread the link thinking it was CF cloth with adhesive... but would be interesting if someone had something like that though...
            This product does exist, it's called prepreg carbon fabric. I wouldn't recommend it to a beginner though, it's more for professional setups. It needs to be stored at low temps (walk in fridge style) and has a limited shelf life. It also requires an oven to cure, so not what you would want for an inlay.
            www.keithbradleyboats.com
            • keithbradley
              • 3671
              #81
              I think driveline could have been one of the issues-- as it was not spinning as freely as the other side was. Usually when you spin you could feel the magnets chiming... this side was not. Seemed like the flex was at a bit of an angle (not lining up as perfectly into the collet). It seemed to line up fine after I loosened up the motor mounts and would spin just as flawlessly as the other side would.
              Makes sense, but I wouldn't rule out other issues such as a damaged motor either.
              1900kv on 6s shouldn't create a terribly high current draw with such small props. Typically, guys get into current trouble with (relatively) higher RPM setups because they prop them the same way they would prop a 30k RPM setup. Part of the reason you see so many twins with higher RPM setups is because they can generate enough thrust with smaller props to be efficient, where single motor setups need a bit more blade area to limit slip. Twins are not the free lunch everyone thinks they are though...they're not magically faster, and it still takes energy to spin a given prop at a given RPM; they definitely don't "split the load in half" as some say, not even close.
              Regardless of current draw though, at that RPM it's certainly not uncommon to crack magnets or run into interference issues with Chinese 4 pole motors, so inspecting the motors isn't a bad idea.
              In regards to cooling, I run twin SK-180s and twin motors in my Donzi mono. I have ONE water pickup on the rudder and series that line through all four components (2 ESCs, 2 motors). There are no Y-splitters or additional pickups; one inlet, one outlet. After running (a total of 6s 10,000mah down to 3.75-3.8v/cell, not just a quick pass or two), the lipos are the warmest thing in the boat. I'm not sure why other people are having issues with water cooling these ESCs, mine have all been quite easy to cool with ZERO modification. It is possible that my rudder pickup is vastly superior to what some other people are running, so take that into consideration, but it is still relevant info.
              • IRON-PAWW
                • Oct 2011
                • 316
                #82
                Ok well - the photo's of the Seaking 180 v3 with the simple cooling mod. Hope that helps you a little. But Kieth is the man with the knowledge and experience. Most definitely, he's a bloke I listen to. :-)
                PERTH AUSTRALIA
                || 2 x SV 27R || Impulse 31 - ver1 || Traxxas Spartan || Kintec Pursuit || Zonda Cat 41" || Insane FE30 || OuterLimits 870mm || TFL Ariane 36" || ProBoat Zelos 48 ||
                • keithbradley
                  • 3671
                  #83
                  Additional cooling can't hurt!
                  • IRON-PAWW
                    • Oct 2011
                    • 316
                    #84
                    Ain't that the truth!
                    PERTH AUSTRALIA
                    • rearwheelin
                      • 2101
                      #85
                      The quad helped my cause . Ran 6s to 2200kv 1515 castles . You couldn't hurt it . Big 43" boat on 4s was 63 mph with marginally sharpens 447's. On 6s it was dumb fast and never burned anything up. The boat would accelerate so hard it would get to it's sweat spot in efficiency sooner.
                      I want to build a quad out of your big boat some day :)
                      --Albert Einstein
                      • iop65
                        • Mar 2013
                        • 367
                        #86
                        iop65: lol gee thanks buddy except if you maybe guessed that I didn't build it-- if I had I would have taken extra precautions. Perhaps you can enlighten me on what you could have done any differently in this situation mr. ducati 1299
                        At the end of the day I have enough "knowledge" to figure out what the builder did wrong and to fix it... as I believe it was the driveline that contributed to this if you can read above. Flex wasn't aligning properly to the motor coillet. But I'm not sure how any of this would even compare to a ducati 1299 though. When I bought my M5 and 750 BMW's they didn't blow up on me after putting the recommended 91 octane gas into them and passing 15 mph... neither did I hit any trees. I usually have an expectation of a certain standard of quality when you pay a little extra for someone or a company to put it together for you where as it should never go BOOM after the first 2 minutes of use. But these components are Made in China after all. That's why I'd rather buy German from now on... they seem to have good stuff even when it comes to these boats it seems.
                        I just want a boat I could use everyday in between work breaks that is reliable and goes fast... so far I'm finding it to be quite an adrenaline rush and I don't have to be inside of a boat or a race car for it. I like the idea of having to build and program something myself and being able to run it-- it becomes a whole other level of fun.
                        "flex wasn't aligning properly into collet"?
                        look at picture nr 4 : it's a mistery to me how someone can get that type of motormount not connect to the driveline correclty , those things bolt right on the motor! you really got to put some serious effort into misaligning this
                        second : if there is really a flex in there ( and not piano wire), i would suggest changing that rather quickly because that style coupler for a flex with that power is not going to make your flex last for a very long time , the grubscrew will destroy it
                        buy some German coupler :mbp , h&m..
                        but they won't fit so you got some work ahead
                        these are things a guy would know when he started off driving a 250cc bike before jumping on a 1299s :-)))
                        and third suggestion ; your cooling intake , not to be trusted like i wrote yesterday
                        good luck
                          • 9481
                          #87
                          Originally posted by iridebikes247 View Post
                          Make sure the timing is set correctly, I've seen some escs get smoking hot because of incorrect timing....not setup.
                          Escs burn but its usually user error (i've done it), maybe the timing was wrong. I would try out a 442 2 blade next time out btw. As for the whole rpm thing....1900kv on 6s is fine as long as the motor works properly. Have you seen others use this motor with good results? A 6 pole is def harder on stuff than a 4 pole but I don't think the margin is enough to push you into failure. This boat should have come back quite cool.
                          I've had that issue once
                          • dmitry100
                            • Mar 2015
                            • 1264
                            #88
                            iop65: The flex actually has grooves for the grubs that would prevent it from slipping. The collet has a total of 3 grubs which I think would hold on the flex nicely. 1 grub on each side for just the flex. We'll see.
                            I'll describe a possible scenario-- which was probably how it went in this case:
                            Completely tightening the motor mounts before laying down the flex and then forcing the flex onto the angle of the collet causing resistance in the drive.
                            • iridebikes247
                              • 1669
                              #89
                              Before the next time you run the boat I would pull both motors out and spin em up on the bench, also pull the face plates off and see if the wrap has loosened, burnt up, etc.
                              Burning 1 esc, whatever it happens. Burning 2 will get old real quick. As far as the flex goes check to see if it looks like its been hit with a torch, extreme heat build up will usually show on a flex.
                              • kevinpratt823
                                • Aug 2012
                                • 1462
                                #90
                                I've been reading along, and my first instinct is a bad motor. Like he said(and a few others), turn them both by hand with nothing attached and see if one feels squishy. I think driveline binding would have to be pretty extreme(and therefore noticeable) to fail as quick as you're describing.
                                My private off road rc track
