Need to fix clear on Aquacraft Lucas Oil, is OEM paint Acrylic or Enamel?
  • SD Eracer
    • Aug 2014
    • 262
    I cracked the seam on my Aquacraft Lucas Oil in a 50+ mph flip, who knew the stock RTR boat could go so fast
    Unfortunately, the flip was rather hard and the seam on the port side cracked wide open. I fixed it, but about 7 x 3 inch section of the clear coating peeled off.
    I was about to use some clear coat I had laying around, but I just found out that you can't use Acrylic Clear over Enamel. But I have no idea what the stock paint is.
    I tried calling and asking Aquacraft Customer support, but they had no clue.
    Anyone familiar?
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    Probably urethane
    In which case, either will work
    • fox88gt
      • Jul 2013
      • 103
      You could try masking off a very small area under the tunnel between the sponsons as an experiment. That way even if the paints are not compatible, it will only disturb a small area on a part of the boat that isn't visible. Unless of course its floating back to shore upside down as my Lucas occasionally does!
      Aquacraft Revolt 30, Aquacraft Lucas Oil Cat
      Dumas 44' Coast Guard MLB (undergoing restoration)
      Dumas 55" Wellcraft Scarab 38KV (NIB kit)
      • montymike
        • 786
        Appliance rattle can white works great check for match hard as nails. What I used on my fiberglass mystic hatch.
