Hi, I was asking myself: can i put the prop shaft on bearing, in order to reduce friction on the drive assembly? What do you think?
Is it possible to put bearing on pursuit prop shaft?
Yes.
I've seen them for 1/4" shafts & struts. I have a 4mm shaft & strut with bearings. So someone will have them for 3/16 shafts & struts. They are needle roller bearings. You'll just have to do some searching.See the danger. THEN DO IT ANYWAY!!!
I would not use a needle roller bearing. They are good for the rpms a gas engine turns but not electric. I'm using ball bearings in all of my struts. The part number is r156. Do a search on eBay. I use the sealed type. You will need a lathe to bore the strut and use no less than 4 bearings stacked. I use 5 or 6.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
There ya go.
Part number & everything.
CheersSee the danger. THEN DO IT ANYWAY!!!
Jeff Wholt sells a strut with 3/16 bearings in it.
My boat have an ajustable stignerIMG_20150503_154809.jpgCan i do the mod anyway?Originally posted by 785boats View PostJeff Wholt sells a strut with 3/16 bearings in it.
http://rcraceboat.com/Storestrut.html
