Flexi help
  • PvtSpoon
    • Aug 2011
    • 83
    Flexi help
    im trying to fine a replacement flexi can only find thread end ?
    its a 3/16th
    any help would be great
    Thanks
  • martin
    • 2881
    If you cant find an off the shelf unthreaded replacement get in touch with Jeff Wohlt @ rcraceboats.com. He makes custom flexes to your requirments, he also comes on this forum at times.
    • Heath M
      • Mar 2008
      • 865
      Why not use a threaded end flex shaft with a lock nut?
      Brisbane,QLD, Aussie
        Can you just grind a flat spot on the threads?
        • Heath M
          • Mar 2008
          • 865
          What do you want to grind a flat spot on the threads for?
          • Luck as a Constant
            Make Total Destroy
            • Mar 2014
            • 1952
            to accept a collet style nut.
            why are you asking tlandauer? he's making a suggestion to the OP.
              I was just thinking out loud since the OP did not specify why he wanted a non-threaded shaft with a flat spot as shown in his picture. I assumed that he has another means of securing the prop.......
              • Heath M
                • Mar 2008
                • 865
                It was a general inquiry no need to get your knickers in a twist lol.
                  Make Total Destroy
                  • Mar 2014
                  • 1952
                  Flexi help
                  Oh they aren't.
                  I'm just trying to wrap my head around the question, as it's quite clear what is going on in the thread.
                  Clearly he wants a collet style shaft, and tim suggested just grinding a flatspot in a threaded Rod to use the same sort of way....
                  How this is questionable, kinda boggles my mind.
                  As Martin suggested, Jeff wohlt
                  Rock on!
                  • Heath M
                    • Mar 2008
                    • 865
                    I read it as Tim asking, if you can grind a flat spot on the threaded shaft, not why can't you.
                    The interpretation of text is different for everyone i guess.
