Catamaran Water Pickup
  • helidan
    • Apr 2015
    • 25
    Guys, referring to the image I've posted would the area indicated by a vertical black line on the back of the port sponson be a suitable mounting location for a water pickup (one 3mm brass tube mounted both sides and brought directly up into the hull)?
    Thanks for any input!
  • grsboats
    • 1011
    you can put it there but will cause reasonable drag.better location is after the prop.
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
    • helidan
      • Apr 2015
      • 25
      How much speed loss could I expect if I were to position the pickups as per my picture? The brass tubes would only protrude past the bottom of the ride pads by a very small amount. Also I'm not racing the boat so I don't need peak performance.
      • grsboats
        • 1011
        I can't say how much but there is a loss and as you said it's a fun boat you can install it as per your pic.
        www.grsboats.com.br
        • Pedro Ramos
          • Nov 2014
          • 144
          For me it work out awesome!!!
          • grsboats
            • 1011
            also works.
            www.grsboats.com.br
            • iridebikes247
              • 1669
              IMO thru hull style pickups on the bottom of the hull work best when it comes to keeping drag to a minimum while providing sufficient cooling. You can go ahead with 5/32" brass tubing and copy whats seen on twin cats. A boat will run better with a pickup through the hull.
