Jolly sport drive
  • Gusmoyer11
    • Apr 2014
    • 171
    Jolly sport drive
    Is this normal for this boat? I just got it from ups.
  • SJFE
    • 4867
    No you have a bent strut. Check for stress cranking too. File a claim.
      First picture showed not only the strut is bent, but it might have been off set on purpose to counter torque? It doesn't seem to exit the hull dead center.....
      Could be just an optical illusion from camera lenses.
      • Gusmoyer11
        • Apr 2014
        • 171
        The strut doesnt seam bent, i was thinking mabe a tourq thing but not sure. Thats why i just post on here. Looking at the new toysport jolly on there website it appears to be straight.
        • Gusmoyer11
          • Apr 2014
          • 171
          Is ups ez to deal with on claims?
            I have not dealt with UPS, so I can't say anything, sorry.
            For a CCW spinning prop, my understanding is that it should be off set to the other side and this is done to monos, like Proboat's IM31, you can see that from the pictures in plain day light. May be it was meant for a CW prop?
            I don't like to speculate.
            • Gusmoyer11
              • Apr 2014
              • 171
              Yah i dont know. I guess ill just try and run it. I sent an email to toysport with the pictures. I hope they give some insight. I really hope i dont have to pull everything apart and reconfigure with a different style strut.
              • Gusmoyer11
                • Apr 2014
                • 171
                Ran top speed at 46.3 mph bounces at low speeds. Launches out of the water like a bandit
                • riflemanbtx
                  • Sep 2011
                  • 17
                  yeah, something isnt right with it, its porpoising heavily and that means the trim is off. if there is a way to adjust that, I would, and send this video to toysport as well.
                    This, may be is a result of the design of the rear of the tunnel. Look at the sweeping up of the bottom, it is the "Biggest Rocker" and when the boat is not fully on plane and aired out, the water interacts with this area (the rocker) , then what you get is the porpoising.
                    Try to gradually apply throttle to full steam, it needs to air out and be on the sponson ride pads, when you slow down, the cycle begins and as the porpoising gets into a rhythm, everything gets worse. I am not saying that this is normal (or not)-------I don't have this boat, as I said earlier, don't like to speculate, but I have seen modification done to this area where a sheet of plastic is placed over this area and the angle is reduced.
                    It is hard to say since your strut looks a bit off, how much THAT is playing ( or not) a role in this behavior is also a consideration.
                    • riflemanbtx
                      • Sep 2011
                      • 17
                      exactly, that is why I suggested sending the video to the manufacture and make sure its doing it by design, or if there really is something offline.
                        Gus,
                        You can search the name of PiroSteel, he is the maker and recently been on the Forum.
                        http://forums.offshoreelectrics.com/...6908-PiroSteel
                        • Gusmoyer11
                          • Apr 2014
                          • 171
                          The part to save this boat is on its way.
                            May I ask what is it? Is it the part I referred to earlier?
                            I understand if you don't want to discuss this so it is cool if you don't want to talk about it.
                            • Spartanator
                              • 1060
                              UPS, I hate UPS.... The first hull was chipped. The second (Keith double boxed it this time) and the box had a Gaping hole.
                              Next time I ship a boat, it will be a heavy duty box.....
                              What I think of UPS:
                              To get back to your topic.... Yep, that doesn't look normal.... It might though, ToySPort has some different designs and they seems beneficial.
