Are you using the prop that comes with the boat? Try a x442, x437/3 or m445. But run and check
Pursuit trim tab setting?
Where is you point of balance (COG)? Monos can be as far back as 27-28% from the transom. I find that the trim tabs can't totally correct the boat's riding attitude if COG is set front heavy. But you need to measure it and be precise . You can even add some weight in the back to see if it helps your boat to run dryer. I run 4s2p and the batteries are at the same place as yours but I bought my boat from a person who took the stock mount out and made some changes, mine is not 100% correct either, it also runs a bit too wet. I find the M445 and M545 worked best, but I have a completely different motor kv than yours. (Leopard 4082/2200kv, 4s2p)Too many boats, not enough time...
Hi,
@ Peter A: I Still run the stock prop. I cleaned it and ''tried to'' Sharpen & balance. My new props will be here somewhere this week.
@ tlandauer: The COG, without batts is aroud there, the black peice of tape (+/-9''):IMG_20150503_094814.jpg. Here is the inside layout:IMG_20150503_100216.jpg.
i've checked the trimtab, and they are at zero. The stigner is set by factory at around 1 or 2 degrees positive.
Today, i want to try a Rio EP plastic prop. It is a 42mm but it is not backcut like the stock one.
My ESC is not in front of the motor, it is on the port side next to the motor , so I have more margin to move the batteries to adjust. Not saying that is what you should do though. Sounds like your stinger is set correctly. A slight positive angle.
As set, the COG is set with the battery(ies) mounted.Too many boats, not enough time...
Hi tlandauer, i already did the same layout as yours this morning before i went to run it. it was better, but a bit unbalanced. i placed the batts right behind the motor and the esc beside the motor, on the left. But also ihad a plastic prop for a rio ep on it. It launches out of the water much better... i cant wait to get my grimracer 42x55 prop!
You need to make sure your port side is slightly heavier to counter the torque. If your battery(ies) is on the starboard , then I would think there is a tendency to lean to the starboard , no?
If you are running batteries on BOTH sides, then keep the ESC in front of the motor, that's what I would do.......Too many boats, not enough time...
I'm setup this way:IMG_20150503_154645.jpgIMG_20150503_154654.jpgIMG_20150503_154809.jpgIMG_20150503_154851.jpg
But i may move the esc in front of the servo.
That's exactly what I have done, but you said it was unbalanced, what was making you saying that. The boat might lean portside, but once on her way, the tourque that is generated by the prop will counter that. Was that the case?Originally posted by boilo56 View PostI'm setup this way:[ATTACH=CONFIG]131497[/ATTACH][ATTACH=CONFIG]131498[/ATTACH][ATTACH=CONFIG]131499[/ATTACH][ATTACH=CONFIG]131500[/ATTACH]
But i may move the esc in front of the servo.Too many boats, not enough time...
Just got back from running mine again. I have it set it up the way Peter A showed above. I am running two 2s batteries though. 27% COG. Are you using a straight edge to check it? I "eyeballed" mine at first and it was running dry and porpoising(hopping). I put a straight edge on it and yup, I was off a bit. Runs perfect now!
Pursuit: T-180, TP 4060/1620kv. Genesis: T-180, GoolRC 2000kv. UL-1: Bone stock. MHZ Tsunami: Full tilt SAW project!
