Hi I am putting together a 27" hydro . Power is a Leopard 3674 - and Seaking 180 ESC . Space is limited for batteries. is is sportboat . But still want to get the right combo of pieces . What Batteries would I be looking for. Thanks . After 19 viewsI am still hoping for a little direction/help with battery issue. I am a new guy with only 26 post under my belt . Paul
Set up
not sure how help full i can be. i have only recently got back into boats.
best i can suggest is work out you CG to see how much weight you need and measure what size (lxwxh) will fit in the boat then find a battery that fits both criteria.
i have just finished building a 24.5'' hydro with very limited room and had to settle for a battery lighter then i wanted but is the biggest that physically fits in.
hope this helps you
What is the kv of the motor?
Which hull is it?
Sent from my SCH-I535 using Tapatalk 2My private off road rc track
BBY 27” Zephyr I found a simlar boat on line . Whiplash 21 built by Dr. Phil. Running gear is as follows. Leopard 3674 2650kv motor with Seaking 180 esc. (2) 4s Hyperion 45c 5000mah lipo packs connected in parallel for 4s 10000mah. Turning an Octura x440/3 blade prop. All purchased from OffshoreElectrics (OSE)Last edited by Pau7060; 04-15-2015, 03:27 PM.
