Motor Maximum Watt Ratings
  • ReddyWatts
    • 1756
    This is what I found for motor max watt ratings on the net. Please help me fill in the blanks, adds or any changes.
    Thanks!
    continuous rating/ 30 second rating
    Neu -
    1506 - 700 watts/ 1500 watts
    1509 - 1000 watts/ 2000 watts
    1512 - 1200 watts/ 2500 watts
    1515 - 1500 watts/ 2700 watts
    1521 - 1700 watts/ 3000 watts
    1527 - 2100 watts/ 3300 watts
    2215 - 3000 watts/ 5000 watts
    2230 - 6000 watts/ 10000 watts
    KB45 - 1500 watts/ 2700 watts
    Feigao
    XL - 800 watts/ 1600 watts
    L - 600 watts/ 1300 watts
    S - 450 watts/ 1000 watts
    380L - 450 watts/ 1000 watts
    SV - BlackJack 800 watts/ 1600 watts
    Ammo 2300 - 700 watts/ 1400 watts
    700sc - 650 watts
    Always calculate your setup Watts and know your motors amp - maximum effeciency rating
    Volts (X) Amps = Watts
    Steven, I cant find any maximum wattage ratings for your motors. Think about adding some to your listings or direct me to them, if I just missed em. thanks
    ReddyWatts fleet photo
  • Ub Hauled
    • Aug 2007
    • 3051
    1527 - 2100 cont, 3300 watts (30sec)
    2215 - 3000cont, 5000watts (30sec)
    2230 - 6000cont, 10000watts (30sec)
    Source: http://www.flydma.com/index.php?cPath=1
    • ReddyWatts
      • 1756
      Thanks, I added them.
      • Doozie870
        • 970
        I will also share the Doozafly inrunner motor watts. Decided to be a player in the sticker on the chinese motor game.
        • AntronX
          • Jul 2008
          • 361
          Feigao 540 Motors Maximum Amps:
          7S = 93A
          8S = 81A
          9S = 72A
          10S =65A
          7L = 88A
          8L = 77A
          9L = 68A
          10L = 61A
          7XL = 95A
          8XL = 83A
          9XL = 74A
          10XL = 66A
          Source: http://img.diytrade.com/cdimg/85838/...1082223033.jpg
          Other Feigao motors: http://www.feigao.com/sdp/85838/4/cp-102738.html
          This thread needs to be made sticky.
          • ED66677
            • 1300
            I was told directly by Feigao (I contacted them when I started with FE boats before I found OSE), that the 540 range was design for 36 or 40 volts max, that would give a max of almost 4000watts for the 7XL! I'm not sure any of these motor with a KV above 1200 can really handle 40volts, a 6XL would spin more than 110000rpm while they are given for 50000rpm max???
            the most powerfull (6XL) at 50000rpm, at 110Amp, would handle a max of 18Volts so the real max power would be 1980Watts!
            Emmanuel
            • Ub Hauled
              • Aug 2007
              • 3051
              I guess their (Feigao's) philosophy is "Aim High... sell what you can".
              I have a hard time believing that any 540 can they have can deliver more then 900-1100watts... but I like to see the glass "half full"... there is a lot of room for improvement.
              • ED66677
                • 1300
                my 8Xl has delivered easily a bit more than 1000watts under 3S, dead cold!
                Emmanuel
                • ReddyWatts
                  • 1756
                  I was just going by my experience with a Feigao 540. Running a 10XL on 18 cells and 3300mah cycle, it would get the motor to 145F. That was 1600 watts max and thought the factory had said 800 watts. I think I recall other users saying they ran them around 1800 watts max in races.
                  This discrepency is interesting. It is clear why users are overloading these motors. We need a definate answer on the Feigao series motors.
                  • AntronX
                    • Jul 2008
                    • 361
                    No, you can't apply that voltage to 7XL. That 40V estimate was probably meant for 16 to 34 turn range, not 7 turn. You can try running 4KW into 7XL, but it will not last. The magnet core will quickly overheat and demagnetize. In your calculation, you took 7XL max amp value of 95A and multiplied by 40V giving 3800W. Guess what, electricity is a funny thing, it does not work like that. At 40V, with x437 prop you will not get 95A, but somewhere between 200 - 300A (crude estimate).
                    IMO, the proper way to estimate power for these motors, is to start with half of max amp value and measure magnet rotor temperature. It may not be possible to open up the motor after every test, pull the rotor out and measure it's temp. Maybe the driveshaft temp can be close enough. Then compare the result to the temperature at which magnets will start to demagnetize. Then get the temps to the threshold, and record your amps and volts during load, multiply and you get your watts. Note that with better cooling it may be possible to get more power out of the motor without demagging it, so this max power estimate will vary greatly between different setups of different people. Someone who is cooling their 540XL with liquid Nitrogen can dump more power into it, than someone using tiny water cooling jacket.
                    • ED66677
                      • 1300
                      Code:
                      Isn't it what I said?
                      Code:
                      Emmanuel
                      • Steven Vaccaro
                        Administrator
                        • 8932
                        Originally posted by ReddyWatts View Post
                        Steven, I cant find any maximum wattage ratings for your motors. Think about adding some to your listings or direct me to them, if I missed em. thanks
                        Feigao doesn't list any good performance charts.
                        From my testing I have found that the 380L is about the same output as a 540S.
                        Steven Vaccaro
                        • Steven Vaccaro
                          Administrator
                          • 8932
                          One other thing to consider.
                          Will a 1515 thats 1500 watts run at
                          10 volts x 150 amps
                          20 volts x 75amps
                          at the same efficiencies?
                          Steven Vaccaro
                          • AntronX
                            • Jul 2008
                            • 361
                            6XL is not the most powerful. 32 turn is just as powerful as 16 turn, as 8turn. Max amps do not represent how powerful the motor is. 6 turn is wound for low volts and high amps. 16 turn is wound for higher volts and lower amps. Either way, power should stay the same. Power (W) = Volts * Amps.
                            Hey, if someone feels like donating few Feigao motors for me to test, feel free to do so. I will post my progress here on the forums. I can return them back, if they survive.
                            • AntronX
                              • Jul 2008
                              • 361
                              One other thing to consider. Will a 1515 thats 1500 watts run at 10 volts x 150 amps or 20 volts x 75amps at the same efficiencies?
                              If more amps means more heat, and more heat is less efficiency, then the answer is obvious. But is it same one 1515 in both situations, or 2 differently wound motors?
