4 & 6 Pole Motors
  • SJFE
    • 4735
    4 & 6 Pole Motors
    Are there any 4 or 6 pole xl size motors under a hundred bucks? I am looking for something a little different for the up comming Vegas conversion.
    Thanks
    Tom
  • electric
    • 1744
    I was hoping there was some good news on your question......
    • Mich. Maniac
      • 1384
      SJFE, I know you dont wanna use one for this build but are the KB motors 4 pole? I cant find anything that says no but with the wattage they can withstand thought they may be. If so I guess that is a correct answer but not one that will help... sorry
      • ReddyWatts
        • 1700
        See if you can find anything on this link?
        PRC Home - iCharger, ISDT, FPV Drones, iFlight, RadioMaster - Battery Chargers - Mean Well & Iota Power Supplies - ProgressiveRC
        ReddyWatts fleet photo
        • SJFE
          • 4735
          Mike they are 2 poles. Thanks Reddy
          • speedracer1129
            • Nov 2007
            • 16
            Hey guys. Check them out.....www.medusaproducts.com
            • electric
              • 1744
              http://progressiverc.com/Brushless_Motor.html
              Wow, talk about information overload!!! That is a whole world of motors!!
              • RPC1
                • Apr 2008
                • 112
                How about Medusa Research MR-036-060-1500V2-5 (L size can)
                It's a little more at 114.95. But at 95% efficiency 6s lipo x 60 amps=1200+ watts.
                They are 4 pole motors with ABEC5 bearings good till 60,000rpm.
                • SJFE
                  • 4735
                  I will look into those RPC Thank you.
                  • azjc
                    • Sep 2008
                    • 57
                    in the Rc MT world they have been very popular a good mid motor between Feigao and Neu ....thier design is similar to a Neu and they are coming out with a 70mm size and rumour has it a 80mm
                    • icelert
                      • Dec 2007
                      • 102
                      Here is a motor that I am going to try out this Sunday in my 1/10 scale hydro. Always liked the idea of having the torque of a brushless outrunner but couldn't find the right kv's until now. Specs out close to the Ammo 36-56 1800kv motor I am currently running. The Scorpion is a 6 pole motor with strong magnets that cog like a Neu when you twist on the shaft. The big question will be heat, hopefully it won't get too hot despite it's claim to be able to take high heat to 350 degrees. A well built, torquey 6.8 oz motor
                      bryan
                      • speedracer1129
                        • Nov 2007
                        • 16
                        Yes. They ARE coming out with a 70 and 80mm can by the end of this month.
                        • Ocean Racer
                          • 502
                          Im try to grasp the concept of how a brushless motor works. I know just like any electric motor you need to run elctricity through it. You also need magnets to turn the staft to create power. Maybe you could break the different parts down for me. I know they last longer and are more efficient then a brushed motor.
                          Failure is the First step to SUCCESS
                          • NorthernBoater
                            • 811
                            A brushless motor operates very similar to an 3 phase induction motor. When the motor is spinning the ESC is switching which wires the current is flowing through. The switching of the current causes the magnetic field to change which spins the motor.
                            • Ocean Racer
                              • 502
                              thank you what is the third wire on the motor and esc do?
