TFL Zonda question
  • nate
    • 1702
    TFL Zonda question
    Just seen that OSE is selling the Zonda, but have a few questions, first off, are the silver stripes, decals, or painted on? 2nd, will the stock motor mounts installed, suit a 40mm motor can like TP or leopards? Thanks
    LMT
    LehnerMotorenTechnik.com
  • Revoltfarm
    • Jul 2014
    • 34
    They are decals and 40mm will work with mounts
    • Gusmoyer11
      • Apr 2014
      • 171
      I was looking at the artr, I really like the looks but is it to good to be true? Is the hull thick enough to last? What kind of conditions will it hold up to, and is it just a saw boat or all around joy ride? Another thing is if bought would everything be getting up graded anyways?
      • nate
        • 1702
        I to have been curious if those yucky stripes were decals, or painted, thanks for the answer Revolt.
        LMT
        • Revoltfarm
          • Jul 2014
          • 34
          I just bought one, havent had a chance to run her yet. But i was pleased with the quality of the boat. Plenty of you tube vids of Zondas running (and crashing). Its fairly wide so not just a SAW boat imo. I wouldnt upgrade untill something has broken. Comes with SSS motors 2075 Kv and two seaking 120a ESC's. I didnt even mount the stock props....Dasboata did a great job on a pair of x447's for me.
          • Revoltfarm
            • Jul 2014
            • 34
            Not as narrow as the Genessis as a better lenght to width ratio
            • pistol18
              • 282
              I have a single CF Fantasm(same hull) and it runs great, turns well. Obviously it doesn't turn quite like my motley crew and lucas oil boats, but they're not as fast either.
              • waterproof
                • Jul 2013
                • 239
                I also have a few question about this boat and i think it's ok to ask them here?
                Do the boat need to be reinforced/ glue or use Carbon fiber to the motor mount or the battery plate like we need on the other tfl boats with fiberglass?
                Is the hull ticker vs smash shark or the genesis?
                • pistol18
                  • 282
                  I don't have any other TFL hulls so can't comment on that sorry.
                  It does seem that the faster you want to go the more reinforcements are needed to survive blow overs, etc.
                  • rude5150
                    • Feb 2014
                    • 339
                    Version 1 is thin carbonfiber, the 2nd version of Zonda cat is made with thicker carbonfiber .I think it's doubled up on the carbonfiber.
                    • waterproof
                      • Jul 2013
                      • 239
                      Ok, didnt know that it was two versions. How do i know that i buy version 2?
                      • rude5150
                        • Feb 2014
                        • 339
                        Morning. I bought mines from Kintecracing.com. Jan told me that the version 2 is thicker carbonfiber. Not thin like the 1st version of Zonda catamaran. I would ask who you bought your Zonda from about what version it is. I would still recommend you strengthen hull. No telling what type of crash one might have.
                        • petej
                          • Jun 2010
                          • 163
                          My second Zonda (V2) from Kintec appears to be thicker and or re-enforced.
                          Zonda's (Fantasm) are great on long, straight runs, not so great for turning at speed. The Motley Crew or other shorter, wider boats are better at turning, cornering with speed.
                          Pete
                          Motley Crew, Impulse 31, Zonda Cat, Genesis, Aqua Rider tug, E-Revo Brushless, Slash4x4
                          • msundsd5
                            Msundsd Racing/ COE
                            • Nov 2013
                            • 244
                            Fellas,
                            The Zonda Hull is not durable for high speed runs unless you reinforce. I have 2 guys I run with that theirs have exploded when crashing, one crashed at 60+ mph ( ran through a wake on the way to doing a speed run )and came apart. The Motor mounts only had epoxy holding them with NO FIBER CLOTH and because of that my boy lost a motor because the lid came off and the mount popped loose. I have seen Version 1's and 2's and there is NOT MUCH DIFFERENCE with thickness. Best advice is to get an inlay and you will have a chance to survive crashes but if you don't, I give you 2 maybe 3 decent crashes before you will be replacing. Guys I run with are running Mid 80's up to 95mph with their Zonda's so we are Veteran's and I am not a rookie talking. Just saying, trying to save you some money and heart ache! Get an inlay , build it right the 1st time, and you will be okay!
                            Lot Boyz Racing and Marine Team...Get Hype!
                            CF Shocker Twin - 93.4mph / CF Daytona Single - 80.2mph
                            FG Shocker Single - 98.3mph / Miss Geico 24" Single - 72.3mph
                              Thanks man, that is what I wanted to know, now, how difficult is it to do an in lay with all the motor mounts and ESC and batteries trays already in there from the factory? In fact, that's the reason why I am holding out because I don't like to tear them down for fear that I will damage it, would much rather just to get a bare hull in that case, just saying....
