Originally posted by Gusmoyer11
View Post
Fighter cat rocket and New Mean machine single
I'm using the airtronics mxv I have steering and throtal set at 100/ I did notice if I go to reverse the prop spins at low rpm. I'm guessing it's like a break?
I can send you a video of it running, ose won't allow the up load. I have iPhone or can email it
Yes, however, I don't remember the specifics on the SF ESC, I disable the reverse feature---although whether you retain the reverse or not should have no bearing on your forward full throttle calibration.
Try setting your throttle end point adjustment at 120%, another words, crank it up to the max until the tx wouldn't let you, I think usually it's at 120%.Too many boats, not enough time...
Ok so crank up the throttle then recalibrate? This is the manufacture manual
Here's another page
http://forums.offshoreelectrics.com/...122#post551122
Yes, crank up your FORWARD throttle end point adjustment to max. The Max means the Max on your tx, can be 120% sometimes....Originally posted by Gusmoyer11 View PostOk so crank up the throttle then recalibrate? This is the manufacture manual
..............Too many boats, not enough time...
Let it beep 3 times and then two more is what I understand.Originally posted by Gusmoyer11 View PostMine goes to 150/ but I did recal letting off at beep two of three
I set mine with only max forward and neutral as zero throttle point....
LOL... it's late, I just read that SF doesn't have reverse feature, I am a bit foggy, been a long day, if that's true and you did observe reverse, something is wrong with your programming procedure, you need to re-read and re-do it again. I use this in my JAE 21 FE rigger and it was easily programmed, may be I was just lucky.Too many boats, not enough time...
Tlandauer has you on the right track. Also the props you are using are too small. The 445 will perform much better. I don't think Mark ever ran it, so you will have to test and make adjustments to dial in the boat. In case you need it, here is a link to the Swordfish manual.
Well last night I think I got the esc calibrated so I will try again this morning once the batts are topped off.
Thank you for you guys help. Nobody near me runs or has run boats. I will be sure to take video! YouTube isn't loading up for me.
Originally posted by Gusmoyer11 View PostWell last night I think I got the esc calibrated so I will try again this morning once the batts are topped off.
The rocket
So it runs 32 on 4s what can I do to get more speed? It handles well, not one flip yet. I'm open to ideas.
