Hobby King princess flex shaft replace parts
  • Shun Tung
    • Oct 2012
    • 124
    Dear all master,
    Anyone know HK Princess boat flex shaft length and size
    ? Or any advise replace parts ?
    Please advise thanks !!
  • HangTheMan
    • Sep 2014
    • 74
    The Princess is a 4mm flex shaft. I replaced mine with a one piece shaft.
    • Shun Tung
      • Oct 2012
      • 124
      Dear HangTheMan
      If you don't mind please tell me this shaft the length and where can find fit this part web suite for sell .
      Thanks !!
      • HangTheMan
        • Sep 2014
        • 74
        You would have to buy the shaft and then cut it down to length. I would not depend on what lengths other's have since there could be variation on how far or back the motor mount is on the boat. Best to purchase and then cut to fit your boat. I got mine at Kintec.
        • Shun Tung
          • Oct 2012
          • 124
          Noted with thanks your reply.
          • Shun Tung
            • Oct 2012
            • 124
            Dear Hang The Man ,
            I just go to find the flex shaft for princess in Kintec . Is it below item good for this
            Boat ? May I know how long fix on this boat need to cut ? Please advise and really
            Sorry make you trouble .
            (4mm Welded Flex Cables 4mm flex cable with 4mm Stainless Steel ground shaft. Excellent quality and very strong. Very well balanced and true running. 15 inches long (380mm). Has a 4mm standard thread.)
            • HangTheMan
              • Sep 2014
              • 74
              Just to confirm. We are talking about the Pincess Yacht from Hobby King. You will have to measure how long it is on your boat and cut it to length. What I did to measure is I inserted it into the flex shaft all the way into the collet. Made a mark at the end of the stinger. Pull it out, take the measurement and transfered the measurement from the end of the flex shaft. Make sure to take into account the the length required for the drive dog, washer and some gap spacing.
              • Shun Tung
                • Oct 2012
                • 124
                Ok ! Thanks you so much !
                • jif9
                  • Aug 2014
                  • 1
                  Originally posted by Shun Tung View Post
                  Dear HangTheMan
                  Thanks !!
                  I'm using the upgrade ose shaft for the sv27. Length is the same. Might need to change your strut bushing also but you can use much wider range of props.
