Hi Model 200 amp & ab Wild Thing
  • andym
    More Go Than Show Prop Co
    • 2454
    Just thought I would let you all know that I rebuilt my 31" Wild Thing after hitting a log and losing an inch of the nose. My kids wanted a boat to run when we go to the lake so a cheap power source and low amps was the go. Settled on a 10xl, Hi Model 200 amp esc and 4s 4350 25c PQ packs. Ran her on the weekend for the first time, started with a CF 45mm prop and Oh Boy 45mph on the GPS . The kids said slow it down so whent to a 40mm CF and ran consistant 39 mph. Temps were packs 105, esc 95 and motor 90. No water cooling on the esc!!!
    I ran a m447 at the end of the day to see what it would do and cracked 50mph!!! That esc only came out at 120 deg F, I was very suprised to say the least!!!! Cheap, fast and low amps!!!!
  • Raydee
    • 1619
    Nice Job! I might have to try one of those ESC's in a nice economy setup.
    Team Liquid Dash
    • Xzessperated
      • Apr 2008
      • 3063
      That is incredible Andy. I know we talked on the phone about this but it makes you wonder why we pay big money for motors and amps when sometimes spending a whole lot less money gets the same results. I guess time will tell about the reliability of the setup.
      Good to see a father that does things with his kids.
      I am posting the pics of your Wild Thing that you sent me on the email to show others just what that 10 XL motor is doing
      • andym
        • 2454
        Thanks Paddy and no one was more surprised than me, I thought that it mite have been miss labeled as a 10xl but with the 40mm prop the run time on a 4350 mah pack is over ten minutes!! This hull runs real dry though and handles like it's on rails.
        • ghostofpf1
          • 399
          As long as you keep the amp draws down near 100 or so with that esc things should be fine.The 200 amp rating must be a misprint or maybe a 5 second peak rating because mine thermals out constantly if pushed much.ie: in my case an 8XL and x440 prop is too much for any lengthy run time at full throttle with that esc
          Ghost
