Pursuit
  • Mph621
    • Jan 2013
    • 150
    Pursuit
    I got my new pursuit decked out leopard 4074 180 amp seaking 60c 4s battery. I floated level and no binding in the drive train. Switched out the stock shaft for a .187 from OSE. Any help with setup would be greatly appreciated. ATTACH=CONFIG]127973[/ATTACH]image.jpg
    • 5660
    Looks good...
    My preferrance is to have the ESC on the port side, because of the rotation of the prop, the heavier side should be on the port side. Also your ESC is pretty far in the middle, make sure your COG is not bow heavy.
    • Mph621
      • Jan 2013
      • 150
      Ok great will do this is my first boat that I will be running thanks for the advise!
        • 5660
        Happy boating my friend!
        • Mph621
          • Jan 2013
          • 150
          Thank you!
          • Make-a-Wake
            FE Rules!
            • 5554
            Yeah, make sure your cog is correct, thats a big batt to have sittin so far up, I run two 2s batts on each side of the motor for weight distribution. Set your cog at 8.5-9" from transom for starters.
            • Mph621
              • Jan 2013
              • 150
              Ok I may try the 2 2s set up but was just getting finishing up the build tonight. Wanted to test float it and was very excited! I hope to try it out soon and hope to get with some locals and really learn. I'm very new to this
              • iop65
                • Mar 2013
                • 367
                put those trimtabs a bit up because a pursuit doesn't need that amount of trimtabs!
                you don't need to cool that motormount with an inrunner , it's just so much longer cooling lines with extra bends without any significant advantage
                it's hard to see , but i think you can put the turnfins way higher and there seems to be about half a meter power lines from lipo to esc
                what prop are you using , Kv motor ?
                those hard nylon straps to hold the lipo down : not my thing , will probably damage the cells
                and as been said ; this boat is going to run very wet
                • Mph621
                  • Jan 2013
                  • 150
                  1900 kv motor. What should I use to secure the battery? Should I shorten the power leads? Octura 3 blade 450? I also have the stock prop.
                  • Make-a-Wake
                    FE Rules!
                    • 5554
                    The 450/3 is pretty beefy, you got an x447/448 2 blade for testing purposes? The 1900kv opposed to a 2200 will swing more prop however...........the 450/3 may be the "one" after its all said and done.
                    Run it the way you have it now to see how she does, check your cog first though, no sense in just plowing along super wet.......
                    If you decide on the 2 x 2s batt config, heres how I would suggest:
                    • Mph621
                      • Jan 2013
                      • 150
                      How would or do you secure the batteries in that location?
                      • iop65
                        • Mar 2013
                        • 367
                        that's a big prop!
                        don't use that!
                        would start with 43-45 mm 2 blad and see how see goes , since it's all new for you you will not get into problems
                        would buy cnc props , they are ready to go, no need for balancing and just fine for your purposes
                        later on the 47mm range should be about right a guess
                        i use "batterie velcro " to keep a lipo in place
                        the 1900Kv ,for me ,is an 5s motor or 6s in a cat but it will do the trick for starters
                        maybe a better picture (inside) ?
                        • Mph621
                          • Jan 2013
                          • 150
                          Can do when I get off
                          • Make-a-Wake
                            FE Rules!
                            • 5554
                            The 1900 4074 is actually a great 4s motor, it will allow more prop for very similar top speeds. 5s will need a smaller prop which there is no benefit from, except losing some bite in corners. The 445 you mentioned will obviously work too, but his kv slaps him right in the high 40mm range on 4s.........maybe the 450/3 will work out in the long run after his testing with less prop and checking temps etc........
                            • Mph621
                              • Jan 2013
                              • 150
                              Make-a-wake
