why??? i think i will try!!!!!
On 5S your 1950 will need a prop like a v937/3 to reach it's top speed. Don't listen to those who say a 2-blade is fastest - they just read it in some book. It is simply not true and many SAW records prove it, including my own.
The Lehners need high advance to reach top speeds. Again, this is proven on the race course, not in someone's back yard pool with a GPS. The higher the amp draw, the more advance is required with the 2-pole motors. Your amp draw will be over 100 amps to reach your speed goal. Start with medium timing and go up if required.
Set the boat on a flat table. Raise the strut so the bottom of the strut is 3mm above the tabletop and parallel to the table. Run the boat and see how it runs. Keep raising the strut 2mm at a time until it either blows over or the speed drops. Set the CG at 33-34% from the sponson transoms. The boat should run on the back 8-10cm of the sponsons at a small positive angle of attack.
You have to realize that if you want high speeds then you will have to limit the way you run your boat. No more than 3 passes, the bring the boat in and check for high temperatures. DO NOT RUN THE BOAT LONGER unless you have proven it is safe to do so. Otherwise you can overheat your motor, ESC or cells and damage them. That is an expensive mistake.
