P1050869.jpgP1050867.jpgI don't use tape I use thumbscrews with a neoprene seal you will never lose your hatch and its a watertight seal!
push button hatch locks - sealing
I've tried cutting them shorter, but can't seem to cut them flat/level? enough, so now leave them long.Attached FilesLegend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
I have been looking for some options about hatch screws and came accross you red boat with the thumb screws. Can you let me know where I can get some like that please? Also, what about the neoprene seal?
Thanks,
KenNEVER SATISFIED RACING
Fine Design 32 V-Hull 4082+6s
how about rc car Proline screw down body mounts you can use oring with them.
The Grim racer push button lock have a oring too.
http://www3.towerhobbies.com/cgi-bin...5&I=LXMHB4&P=K
Kbb has the seal.Originally posted by Tamelesstgr View PostI have been looking for some options about hatch screws and came accross you red boat with the thumb screws. Can you let me know where I can get some like that please? Also, what about the neoprene seal?
Thanks,
Ken
I got my thumb screws at Home Depot, but some guys get em online.
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...
I put a silicone O-ring (shock seals for my rc cars) on under the spring. It does the trick very well. You just need the right size that will fit down into the recess nice and snug. Some hatch locks you can remove the lower cross pin if it has a set screw (requires some heat, as that loctite is solid), others you can stretch the o-ring over the top button, then work it down to the bottom of the spring. Along with some foam rubber weatherstripping tape around the hatch, I've had boats upside down for 10 minutes and only get a shot glass of water at most.My private off road rc track
These have the O ring too.
http://www.ebay.com.au/itm/CNC-alumi...item1e7f98910cSee the danger. THEN DO IT ANYWAY!!!
