data logging
  • ls1fst98
    • 905
    data logging
    does anyone know of a data logger to read amp draw that goes higher than 150a? i cant seem to find one.
    also, anyone know if bluetooth works through carbon fiber?
  • siberianhusky
    • Dec 2009
    • 2206
    Eagletree can easily be modified to go to 300. You do need a decent meter to calibrate it when you are done.
    No real idea about the bluetooth, I would think no or at a reduced range as it must be some kind of radio signal. Just guessing...
    • NativePaul
      Greased Weasel
      • 2770
      If you do a search you can find instructions here on how to modify a 150A Eagletree datalogger to 300A, or there are high power ESCs with datalogging built in like MGM Compro 160/250/280/400/800A, Castle Creations 200/240A, Swordfish Plus 200/300A.
      Bluetooth operates via radio transmission on the 2.4ghz frequency band, as such carbon fibre will block most of the signal, also if your radio system is 2.4ghz one may interfere with the other, the flyboys keep there FPV gear well clear of 2.4ghz to avoid clashes.
      • ls1fst98
        • 905
        Ahhhh yes forgot it's on 2.4 as well. Damn, I was thinking of making an arduino based ammeter. I could try n build it, found a ammeter to hook to arduino for 25$
          There was a logger that I tripped upon on a euro site. Dang, I can't remember the name of it though.
          Found it: The Unilog http://www.rc-raceboats.de/shop/lng/...=N&language=en
          and the 400 amp module http://www.rc-raceboats.de/shop/lng/...nsor-400a.html
          • jcald2000
            • 786
            My Eagletree mod passes 372 amps in my set ups, not constant but peak. The highest constant I have recorded is 243 amps on 8s 2p for 1:13 minutes.
            I normally run about 200 amps average.
            • photohoward1
              • 1781
              Man Jim those sail boats are hauling the mail!
              • jcald2000
                • 786
                Yes they are!
                • ls1fst98
                  • 905
                  Is the mod a basic rewire of the connection for th eagletree v4? If so it's Def cheaper and easier than the arduino option. I'm trying to see where I stand on my twin 2028's before I really start propping up. And my castle 240hv esc do not data log.
                  • ls1fst98
                    • 905
                    Oh and recalibrate
                    • jcald2000
                      • 786
                      If you are going to test with it and your not trying to impress the world with your numbers and you can follow my directions, just measure the wire loops carefully and solder on as shown. One of my club members bought a used one where the original owner figured he knew better and used wires that were at least 1/2" too short making it useless and probably out of calibration range. Make sure you use the same gauge wire as on the data logger.
                      • ls1fst98
                        • 905
                        all im trying to do is make sure im not over doing it on my given esc's. just one more precaution as well as checking temps.
                        • CornelP
                          • 793
                          Try this one:
