Mono hull motor mount attachment.
  • DeltaForceMan
    Old No 7
    • Dec 2014
    • 101
    I have a carbon fiber motor mount for my neu 1527 motor. I purchased this mount from ose and it has all the little holes along the bottom for epoxy to flow into. My plan is to use some wood around these holes to dam it up a bit. I will be fiberglassing the wood to the bottom of hull for strength.. my question is would balsa be strong enough for this??
    Good times had by all!
  • iridebikes247
    • 1669
    Which epoxy are you using again?
    I imagine you're damming it because you want to use a decent amount of epoxy, without having it run, correct? If thats the case I would get an epoxy additive like micro fibers or something, to bulk it so it doesn't run. Then if you want use fiberglass or cf tape to finish it off. I did something similar recently using thickened epoxy and black pigment, posted a pic that might help.
    • DeltaForceMan
      Old No 7
      • Dec 2014
      • 101
      Nice, looks clean.
      • DeltaForceMan
        Old No 7
        • Dec 2014
        • 101
        I'm thinking about using g flex and I already have some milled fiberglass to mix in
        • DeltaForceMan
          Old No 7
          • Dec 2014
          • 101
          Unless you think there is a better epoxy to use
          • iridebikes247
            • 1669
            I think a few members on here have used gflex and really like it, but I can't comment as I haven't used it. For motor mounts I could see why it would make sense, but I've never had a problem with west systems 105/207. I have taped motor mounts with carbon fiber, and have left others with just epoxy. Neither has broken, so up to you.
            I tend to use
            colloidal silica + high density west systems additive.
            Together it makes something ridiculously hard and strong. I use masking tape spaced appropriately to make a nice epoxy bead, then a putty knife to get it flat.
            For me, I always use epoxy for motor mounts, aquarium silicone for battery trays.
            • RCBoaterGuy
              • Dec 2014
              • 203
              I've been using this epoxy for several years and nothing has come loose... http://www.harborfreight.com/uick-se...oxy-68386.html (that's the wrong SKU num & price) correct SKU = 92665, it's on sale now for $1.99
              I sand the surface's to be epoxied with very course (80~100grit) sandpaper to promote adhesion - sets within 5-minutes so you don't have to worry about running. Plastics, wood, fiberglass & other materials no prob.
              I gather your talking about one of these 2... http://www.offshoreelectrics.com/pro...od=ose-80230-b - or - http://www.offshoreelectrics.com/pro...prod=ose-80210 - if yes, sand the bottom of each upright with course sandpaper, run a bead of epoxy on it & attach to your hull.
              After that you can run a bead of fiberglass resin or finishing epoxy on each side of each runner one at a time till it's built up to your liking.
              Or go with iridebikes247 suggestion & run strips of this stuff... http://www.cstsales.com/glass_tape.html through the openings (or length wise along the base) to tie it to the hull.
              AQ MiniMono - CopterX 430XL 3550kv BL Outrunner + Seaking(V2) 35A on 2S VERY Fast
              Pro Boat SW26v3 - 2860-2600kv + Seaking(V2) 90A on 3S, Build in Progress
              Pro Boat Stealthwake 23 - Stock For Now - Brushless Down The Road
              • DeltaForceMan
                Old No 7
                • Dec 2014
                • 101
                Yes, my mount is the same setup as your link. Think I'm just going to use thickened west systems gflex and I will be mixing in some milled fiberglass.. I understand prep is everything so acetone and sanding will be done before epoxy is used.
                  • 7512
                  I've used Marine Goop on several of my builds...works well.
                  • RCBoaterGuy
                    • Dec 2014
                    • 203
                    Denatured alcohol would be a better surface cleaner than acetone - especially if your dealing with plastics.
                    • DeltaForceMan
                      Old No 7
                      • Dec 2014
                      • 101
                      I'm dealing with fiberglass not plastic
