What to do??? Need help BIG TIME!
  • Heath M
    • Mar 2008
    • 806
    Thank you both very much, it is the sensible thing to do, although visually DISTURBING!
    I must inject a bit of self deprecating humor here: I am very near sighted and in one eye especially, so even with prescription glasses I don't see a straight like due to the high index of correction, my brain has learned to compensate for it most of the time, so when I realized this issues this morning, I thought my brain wasn't kicking in to do its thing.
    I only ever see straight after a few drinks, is 830am to early to start lol.
    I was looking at buying the same hull and did quite a bit of research on it, hence seeing the same transom issue, but decided it would be to small to race here.
    Might be worth sending H+M an email with those pics and asking the same question.
    Brisbane,QLD, Aussie
      • 5660
      I will send H&M an e mail, great suggestion! Thanks!
      • CornelP
        • 745
        Do not waste your time with emails... I had the same problem years ago and I got an answer saying that it was designed this way... with no other details. I installed everything perpendicular to the table and it works perfectly.
        Make sure you reinforce the seam on the full length, mine opened after a high speed crash (and Oliver blamed it on the speed). You be the judge, but it seems to me the FG was not fully infused with resin...
          • 5660
          Rocstar (Joel) helped me with the lay up, he was careful to point out that there was one area where there was a bubble, separation between one of the layers. He took care of that. Joel did a fabulous job , and the seam was reinforced as much as possible, the difficult thing is to get to the tips and under the deck, this was impossible, and I don't believe in pouring two-part expanding foam under the front deck either. Well....
          I actually thought about the possible answer from the manufacturer, you have just confirmed my feelings, but knowing what to expect, I guess there is nothing that I would lose from shooting Oliver an e mail.
          Thanks much for the heads up and your experience with the hull.
          • flraptor07
            • Aug 2013
            • 2451
            Sand the seam and put a coat of primer on it, sand it again, now put a coat of paint on it. If it came out right now you can't see the seam. Now mount the rudder the way it's supose to be, problem solved!
            • iridebikes247
              • 1528
              ^What flraptor said
              Definitely use the table as your guide
                • 5660
                Originally posted by iridebikes247 View Post
                Thanks for the brilliant idea!
                I thought I will at least mask that with pin stripe. I have had this hull for a long time and been staring at that line for quite sometime, as i said, because of my assumption, yesterday's discovery ( that it being the level line) was just too much of a mental shock/disturbance. I have recovered somewhat and mounted my rudder, think everything should work out.
