I'm trying to epoxy two pieces of carbon fiber together I scuffed up both sides mixed up a batch of epoxy and the two pieces chipped right apart there was no bond i'm using zap Epoxy it's Z proxy finishing resin looks like I might have to buy some new epoxy I thought this would bond to the carbon fiber
Carbon fiber epoxy?
Finishing resin is....for making a finish, not great at bonding. JB is very good, parts need to be free of any oil or grease and roughed up a bit though. What type of carbon fiber? For what purpose are you gluing the parts together?
As said, Finishing Epoxy ( PT-40) is for finishing, meaning that it is much easier to sand than the PT-39 ( 30 min. epoxy). It cures with a more brittle quality than its counter part. However, it should not chip right apart like that. How long has it been on the shelf? I never use that for structural bond but on occasion I have used the PT-40 MIXED with milled fiber glass with no problems whatsoever. I just made a rudder bracket extender out of CG plate, 2.5mm, just to give you an idea, I sand with 80 grit sand paper and when I rub the areas where I plan to glue, the friction is very noticeable.
Just my $.02Too many boats, not enough time...
Well, the little amount on the inner wall of the cup is always brittle, especially for the PT-40. Yes, your results will be better with PT-39.Originally posted by klbo View PostIt was pt 40 but the mixing cup hardend very brittle time for new epoxy?
Sand and clean with acetone before applying the epoxy. I also clean the mixing cup with acetone and the mixing stick. JB weld is great but it doesn't flow well, so I use different epoxy depending on the application and location.
Sent from my D6708 using TapatalkToo many boats, not enough time...
I use jb weld on everything that I do not want to ever come undone. It has not let me down yet. I've had hard flips at 90+ and it held. I use other epoxies for the esc covers and stuff I may change later.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Here's an excerpt from the West System (my favorite) Users Guide:
"Clean Bonding surfaces must be free of any contaminants such as grease, oil, wax or mold release. Clean contaminated surfaces with lacquer thinner, acetone or other appropriate solvent."http://www.westsystem.com/ss/surface-preparation/This is NOT a toy?!?
Yes definitely nitrile gloves even when you are sanding carbon fiber definitely don't want to get any of that On you and yes all my parts were clean it even popped off the wood really easy bought some west systems 105 epoxy the 207 Clear Hardner
