OS outboard leg bump in the road.
  • Zen
    F1 junkie
    • 123
    I have a Lep 3674. Wanted to mount it on a os outboard leg. I had a 3650 that fit perfectly. I have the adapter that was bought from ose. Problem is, and I'm sure there is a easy fix but I am green to electric, so need help with a solution. The collet fits on the motor shaft but is to long so there is a gap between the mount adapter. The collet is up as far as it can go on the motor shaft. Just too long. The sensible thing to do is cut down the motor shaft but I want to make sure befor I do any cutting. If it's needs to be cut is there a standard length that should be cut? Or the other solution would be a adapter or spacer for the adapter if there is one. Thanks.
    Doesn't matter, real or RC, boats are just a hole in the water where you throw your cash.
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    It's not uncommon to trim the length of the motor shaft on FE tunnel leg conversions, at least not for the last 5 FE tunnels I've built. For me it was more to get the proper flex fit/ end play. The 3674 is taller which means a slightly higher CG and shimming it up higher to make things fit further raises the CG and the "top heavyness" . Use a Dremel cutoff wheel & cover the motor bearing with tape to keep it isolated from the cutting dust
    • Doug Smock
      • 5359
      Originally posted by Zen View Post
      I have a Lep 3674. The collet fits on the motor shaft but is to long so there is a gap between the mount adapter. If it's needs to be cut is there a standard length that should be cut?
      I would measure the gap you have and cut that much plus a 1/32" or so off of the motor shaft. You don't want to put the cable in a bind having the shaft a bit long.
      Good luck
      D.
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • Zen
        F1 junkie
        • 123
        Ok it's done. The collet set screws just cover the flat spot. There is no room for the flex shaft to have play. It's right there. If it binds I'm screwed. Also the prop has some resistance. So more of the shaft needs to go. If I cut anymore one of the set screws will tighten above the flat spot. The other will be on the flat part. Is it ok to just have one set screw tighten on the flat part. Or is a file in order.
          Yes, That 's what I have to settle for on some of mine, you can always use a grinding disc to 'lengthen " the flat spot. Either way, make sure you use blue thread lock compound on the set screws especially the one that has the flat spot.
          • Zen
            F1 junkie
            • 123
            Thanks all. And Merry Xmass
